09-23-2011 05:04 AM - edited 03-16-2019 07:09 AM
hy all
Since i am a beginner to this domain My doubt might be found silly but My question is can we configure a PLAR number to a IP phone and if so how can we do it ? and if not why cant we do it ? please do clear my doubt
Thanks in advance
P.Vishvak
09-23-2011 05:32 AM
The answer is most likely "yes". The "how" depends on what you have deployed. Can you provide the following:
1. Do you use CME or CUCM?
2. Is the station you want to originate the call from an IP phone or an analog station?
3. If analog station:
- What kind of gateway?
- If CUCM + analog station, what signaling protocol (SIP, H323, MGCP, SCCP) is the gateway using?
Bill
09-24-2011 10:40 PM
I am using a CUCM, the station frm where the call originates is a digital line, the gateway uses MGCP protocol. please do tell me as to how we can configure a PLAR line to a IP PHONE.
09-25-2011 06:58 PM
OK. For illustration purposes assume that your target extension (the one you want to ring) is 1234/PhoneDN_PT. You can create a "plar" configuration by doing the following:
1. Create a partition: Plar_Grp01_PT
2. Create a CSS: Plar_Grp01_CSS
3. Create a translation that is in Plar_Grp01_PT and is configured with NO DIGITS. Ensure that Urgent Priority is checked on the translation. Assign a CSS to the translation that can see PhoneDN_PT. Change called party transform to 1234
4. Assing Plar_Grp01_CSS to the MGCP GW port CSS.
Basically, the "no digit" translation can be read as "any digit". As soon as the phone goes off hook the translation in step 3 matches automatically. Since it is flagged with urgent priority, CUCM uses the translation to route the call.
HTH.
Bill
09-25-2011 09:10 PM
when we say translation in step 3 does that mean we hav to create a translation pattern which says ' XXXX ' which is then placed to a certain group and how do i configure with NO DIGITS.
please do clarify my doubt.
Thanks in advance again
09-26-2011 05:54 AM
To program the translation pattern with NO DIGITS you simply do not put in digits in the "pattern" field. In other words, leave that field blank.
Bill
09-26-2011 08:21 AM
thanks a lot bill it was a helpful discussion with you hope to share more on the coming days
Thanks in advance
P.Vishvak
