IP Telephony and Phones
Labels
Dear All,I currently have a customer who wants to use CUBE for inbound DTMF conversion:-Q1)  Currently, my customer topology is as follows:-LAN ---- CME (2901)  ---- FW ---- 2821 ---- InternetIs it true that I can't put the CUBE on the 2901, and i ha...
huntl by Level 1
  • 623 Views
  • 1 replies
Hi ,I am wondering if it's possible to get the called party line state when i call a busy ipphone, ( a message for example : user busy or an icon )I have all the ip phones configured with a busy tone : 2 , so they can receive 2 calls .I want  my ip p...
Hi All,I am trying to pull the CDR from CUCM and I found that the below services are activated. But the service CDR Enabled Flag in system parameter is false in both the nodes. If I make that service as true whether that will help me to pull the CDR ...
Hi all,I have CME connected to Telco via SIP trunk, the SIP provider uses g.711alaw and I need to configure Tcl for AA, and Tcl should be configured to use G711ulaw so that I configured MTP but any time I am trying to call the AA the Tcl answers me b...
We use a Verizon Business SIP Trunk, with 3845 CUBE 12.4.24T. CallManager 7.0(2) and 7962G(SCCP) handset. All calls have dynamic MTP and are G711.Had the exact same symptoms again twice, only I was dialed out to 704-XXX-XXXX. I hit the QRT button to...
I bought Cisco 9971 and want to use it as simple stand-alone SIP phone, but there no any settings to setup SIP accounts. Before that I used Cisco 7960 with such problem but I found how to upgrade that to SIP firmware, and than can find SIP settings o...
teleclick by Level 1
  • 4393 Views
  • 3 replies
