Can we configure Meet-me with authentication on CUCM 8.6 ?
vishal shinde
we are using CUCM 8.6, in that we have configured Meet-me, so, now we are using it without any authentication so, it is totally non-secure.
So, guys, can you please help on this ??
Jaime Valencia
No, you cannot (at least not with just CUCM). There are literally, hundreds of posts asking the same thing on CSC, please search before you ask.
Your options are to front-end with Unity/CUC or to create a UCCX script, either option can be found on the previous threads on the topic here on CSC
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Yes jaime... there are multiple posts in forum...
But, when i checked in CUCM 8.6, there are obtions for meet-me, as per below snap, authenticated, encrypted.
So, what is use of those options ???
Please define....
They would refer to secure cluster configurations - it means authentication of the device (the conference bridge) and encryption of the RTP.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
