10-01-2011 02:16 AM - edited 03-16-2019 07:16 AM
Hii...
Is there anyway to put password on IP Phone so only the intended person can unlock it???? Same as what we do for PC's. Also i want it to be user controlled means user can change the password according to him and don't use administrator defined password.
Thanks in advance.
Pankaj
10-01-2011 02:57 AM
You can consider using Extension Mobility - basically each user has a 'device profile' which appears on the phone when they log in (using user ID and PIN).
Their number and settings are applied when they log in, and the phone reverts to a base configuration when they log out (which can be done automatically after a set period of time).
Typically you configure the base configuration of the phone so that it can only dial emergency/internal destinations; and the users' device profile would 'add' rights to dial externally when they log in.
Aaron
Please rate helpful posts..
10-01-2011 04:18 AM
Thanks a lot Aaron for reply.
Its a really amazing way to implement user id and pin for each user. I will download some references, test it and let u know.
And Is there any other way except extension mobility???
Once again, thanks for your valuable suggestion.
10-01-2011 11:01 AM
The poster failed to specify what product or version they are running. It should be noted that this is somewhat possible in CME using Call Blocking. For CUCM you could also create a new set of route/translation patterns which require a Forced Authorization Code, place them in a new partition and CSS, and apply that CSS to the device.
PS- A Google search turned up several third-party options that provide this feature as well.
10-02-2011 10:47 PM
Hi Janathan.
I am using Cisco MCS 7835 server with CUCM version 8.5.1.12025-1.
I have tried the Forced Authorization Code but problem is FAC is not bound the user. means if a person knows the other person FAC Code, he can use it for dialing.
I want each user to have its own dialing code and it should be bound to the user's id in someway so others can't use.
As suggested by you, can u plz tell any third-party options for the solution if available?????
