Cannot add Ip phone 8831 in CUCM
Filipe Viana
Try add the phone 8831 but cannot see in my CUCM.
I have this version:
                     CUCM 9.1.1.20000-5
Phones are registering as SCCP, I have uploaded the pack cmterm-devicepack9.1.2.13080-1.cop​.sgn, but it gives me the next error:
Major, minor and maintenance version numbers obteined from the name do NOT match those of the current version.
any idea?
tonyperla
Hi Filipe,
Since you are running CUCM 9.1.1 and the device pack you are trying to use is for 9.1.2, the message you are receiving is understandable.  You may want to try a device pack for CUCM 9.1.1, for example - cmterm-devicepack9.1.1.21033-4.cop.sgn
Hope this helps
Tony
Please rate helpful posts
Tony
Jaime Valencia
Upgrade to 9.1(2), then apply the latest DevPack
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix_chapter_00.html
java
if this helps, please rate
