10-17-2012 06:37 AM - edited 03-16-2019 01:43 PM
I'm trying to block all PSTN calls except for some people, below is my config:
I want to block outside calls when user enter 0
but when I test it all user are allowed to make PSTN calls?
any help?
telephony-service
load 7921 SCCP69xx.9-3-1-3.loads
load 7937 apps37sccp.1-4-4-0.bin
load 7960-7940 P00308000600
load 7945 SCCP45.8-3-2S
max-ephones 100
max-dn 400
ip source-address 10.1.0.211 port 2000
timeouts interdigit 3
system message IT Support 1020
url services http://phone-xml.berbee.com/menu.xml
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 5123781291 extension-length 4
max-conferences 8 gain -6
moh flash:moh.wav
dn-webedit
time-webedit
transfer-system full-consult
after-hours block pattern 1 90 7-24
after-hours day Sun 13:30 08:00
after-hours day Mon 13:30 08:00
after-hours day Tue 13:30 08:00
after-hours day Wed 13:30 08:00
after-hours day Thu 13:30 08:00
create cnf-files version-stamp Jan 01 2002 00:00:00
Solved! Go to Solution.
10-17-2012 07:05 AM
Hello Saleh,
Did you configure COR LISTS?
Take a look:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Rate this if helps!
Leonardo Santana
10-17-2012 07:30 AM
Your after hours block pattern is 90, so it would not match when someone dials a 0.
See more about after hours block setup in this link, http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_a1ht.html#wp1128841
Also as Leonardo wrote, you could do this with COR.
Read more about setup of COR in this link, http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Please remember to rate helpful responses and identify helpful or correct answers.
10-17-2012 07:05 AM
Hello Saleh,
Take a look:
Rate this if helps!
Leonardo Santana
10-17-2012 07:30 AM
