Cannot ping to ftp server ip address from CUE
pyaykhaing789
Hello Everyone,
I am having a problem with CUE interface. I need to do a clean install the language file pkg to cue and cannot ping to ftp server form cue module.
Here's my CUE config, I'll really appreciate if you guys can help.
PK
interface Loopback0
no ip address
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.42.2 255.255.255.0
interface FastEthernet0/0.100
encapsulation dot1Q 100
ip address 192.168.44.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Internal-Service-Module0/0
ip address 192.168.100.1 255.255.255.252
service-module ip address 192.168.100.2 255.255.255.252
!Application: CUE Running on AIM2
service-module ip default-gateway 192.168.100.1
hold-queue 512 out
2 Accepted Solutions
Your ftp server is not using 192.168.42.2 as default gateway, or has firewall enabled.
I would run a traceroute from the FTP server to the CUE IP and find out where it is failing, and if it is going out the right hops to the network that the CUE is on.  You can do the same thing for the CUE->FTP direction.
FYI, if you can session into the module from the chassis the device is in with 'ser i0/0 sess' then the configuration on the router for CUE is fine, assuming you don't have a duplicate IP address anywhere.
15 Replies 15
paolo bevilacqua
Read again the cue docuemntation.
is0/0 address must be unnumbered from voice vlan
CUE address must be taken from voice VLAN. Gatwat is the rotuer address.
Then you have an host route pointing to IS module.
Thank for your reply. Here's my update config. I made changes according to not only cue docement also your advice but still the same.
cannot ping to ftp server.
Config
ip unnumbered FastEthernet0/0.100
service-module ip address 192.168.44.3 255.255.255.0
service-module ip default-gateway 192.168.44.1
hold-queue 512 out
ip route 192.168.44.3 255.255.255.255 Internal-Service-Module0/0
Errors
CUE# ping 192.168.42.2
PING 192.168.42.2 (192.168.42.2) 56(84) bytes of data.
64 bytes from 192.168.42.2: icmp_seq=1 ttl=255 time=700 ms
64 bytes from 192.168.42.2: icmp_seq=2 ttl=255 time=4.50 ms
64 bytes from 192.168.42.2: icmp_seq=3 ttl=255 time=59.0 ms
64 bytes from 192.168.42.2: icmp_seq=4 ttl=255 time=340 ms
64 bytes from 192.168.42.2: icmp_seq=5 ttl=255 time=452 ms
--- 192.168.42.2 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 2379ms
rtt min/avg/max/mdev = 4.507/311.475/700.928/257.023 ms, ipg/ewma 594.800/510.68
8 ms
CUE# ping 192.168.42.222 (ftp server)
PING 192.168.42.222 (192.168.42.222) 56(84) bytes of data.
--- 192.168.42.222 ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 4007ms
, ipg/ewma 1001.880/0.000 ms
I used Filezilla server as my ftp. So, my laptop is FTP server.
My Lapotp default gateway is 192.168.42.1 which is Firewall ip.
Do I need to add new static route to my laptop? or Is there other way to install license file to cue?
Thank you,
PK
Set static route on the ftp server
Route to CUE subnet via gateway CME IP
Hi bevilacqua,
I changed my laptop default gateway to 192.168.42.2 but still cannot. Any idea?
Thanks for your kind help.
PK
brendand05
Can you ping the T/FTP from CME?
Did you reload the service module after the above config change?
Yes, I can ping from CME.
I also did reload the service module after ip address had changed.
why do i need to add a supervisory disconnect tone? (sorry I'm new to IP Telephony)
PK
brendand05
Hi you don't need disconnected tone......posted reply in wrong tab
You need to add a route to the TFTP server to send traffic destined to the CUE subnet to the CME router
Let me know how you go
Hi brendand,
I added default route to TFTP server but still cannot ping..
Thanks for your kind support.
PK
Post up your gateway config.... including the ISM and FA0/0.100 interfaces, and the static route config.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aaron,
Please find the attached file for gateway config.
Thank you.
PK
Wow..After doing many tests using all of your suggestions/advices, I can manage to ping my tftp server
Here's how I solved.
I just changed my tftp server default gateway to 192.168.42.2 which is CME. Previously, it was 192.168.42.1 which is Firewall.
Not finished yet, I also need to disable my window firewall and Kaspersky Firewall. If not, you cannot get reply form ftp server.
Many thanks to Mr.Bevilacqua and Mr.Steven
Sincerely,
PK
