Cannot telnet or ssh to new vg204xm
Marc Reid
I just installed 2 new VG204XM gateways that are functioning fine but I cannot telnet or ssh to them. I can only connect via the console port.
Their config was copied from a VG204 and then only the host name, ip, etc was changed to reflect the location I installed in.
How can I enable telnet or ssh on these 2 devices?
Nadeem Ahmed
please refer to below document
http://www.cisco.com/c/en/us/td/docs/routers/access/vg202_vg204/quick/vg2_4qsg.html
Br,
Nadeem
Br, Nadeem Please rate all useful post.
This document has no information on enabling remote access at all.
I would like the CLI commands to configure outside of the initial setup.
Marc,
Did you ever resolve with being able to SSH to your VG204XM?  I have one setup and working fine via telnet, but I want to disable telnet access and enable SSH for security reasons.  The standard CLI command of "transport input ssh" is not being accepted on the VG204XM.
Paul
