Cannot transfer calls while Built in bridge is on
Samer R. Saleem
Level 4
Level 4
Why call transfer gets dropped when Built in bridge option is enabled on CUCM?
George Sotiropoulos
Can you check the "Call Forward and Call Pickup Settings" on the phone/DN you are using? You need to make sure that the specific Partition/CSS are able to call the Bridge
George
Hope the above helps,
gsotirop
