cant dial to any toll free number
Abood
hello
i have issue . i cant dial to any toll free number for example : 800XXXXXXXX ...
BTW . it was working but now it doesn't
This is my route patterns : 9.8!
so how can i know where is the issue ?
Jaime Valencia
Depending on your call flow review debugs and/or traces to find the disconnect cause and then adjust the configuration as needed.
java
if this helps, please rate
Dennis Mink
Start by using the dialed number analyzer in cucm to simulate the number being dialed, so you can verify if the correct dial pattern is getting hit. If it is, get onto your PSTN gateway and run a debug to see if the call is going out (debug ccsip message or debug isdn q931).   see what is getting called and if necessary call the provider to see why its denied if you are sending the call out
Please remember to rate useful posts, by clicking on the stars below.
HARIS_HUSSAIN
Go to Dialled Number Analyzer and Simulate the Call. Paste the output here to further troubleshoot.
Refer Below Video on How to user DNA.
https://community.cisco.com/t5/collaboration-voice-and-video/analyzing-dial-plans-using-dialed-number-analyzer/ba-p/3099910
& Plzz Rate Helpful post
