cant enter mgcp commands on 2911 router
baselzind
Level 6
Level 6
im trying to configure a voice gateway 2911 router but i cant enter any mgcp or ccm commands , it is a license issue or a ios issue? the current ios is
c2900-universalk9-mz.SPA.154-2.T.bin
and license output:
Technology        Technology-package                      Technology-package
                           Current                        Type             Next reboot
ipbase                 ipbasek9                  Permanent               ipbasek9
security               None                        None                         None
uc None              None                        None                         None
data                     None                       None                          None
NtwkEss             None                        None                         None
CollabPro            None                       None                         None
You can first install it in the router flash using TFTP, please check the example below
881GW-demo#copy tftp flash
Address or name of remote host [192.168.1.3]?
Source filename []? 881GW-adv-IP.lic
Destination filename [881GW-adv-IP.lic]?
Accessing tftp://192.168.1.3/881GW-adv-IP.lic...
Loading 881GW-adv-IP.lic from 192.168.1.3 (via Vlan1): !
[OK - 1193 bytes]
1193 bytes copied in 0.424 secs (2814 bytes/sec)
Then issue the following commands
license install flash: licensename
reload
You can refer the following post
https://supportforums.cisco.com/discussion/11091091/how-upgrade-my-license-k9-sec-k9-cisco-2911-router
Manish
8 Replies 8
Manish Gogna
Looks to be license issue, you only have the ipbase license which entitles you to the following
Technology Package
Details
Software Activation Feature Licenses
Right to Use Feature Licenses
IPBaseK9
Offers features found in IPBase IOS image on ISR 1800,2800 and 3800 + Flexible Netflow + IPV6 parity for IPV4 features present in IPBase. Some of the key feature are AAA BGP, OSPF, EIGRP, ISIS, RIP PBR IGMP, Multicast DHCP HSRP, GLBP NHRP HTTP HQF QoS ACL, NBAR GRE CDP, ARP NTP PPP PPPoA PPPoE RADIUS TACACS SCTP SMDS SNMP STP VLAN DTP IGMP Snooping SPAN WCCP ISDN ADSL over ISDN NAT-Basic X.25, RSVP, NTP, Flexible Netflow etc.
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/software-activation-on-integrated-services-routers-isr/white_paper_c11_556985.html
You will need the UC license for voice features, once you have the license you can activate it via the following procedure
1)      conf t
2)      license boot module c2900 technology-package ucK9
3)      exit
4)      write memory
5)      reload
Manish
isnt it enough to upload it via tftp then issue the command
license install flash:tftp.lic then reboot?
[OK - 1193 bytes]
reload
Manish
i was informed by my manager that it should have the needed license , any chance the feature is there but needs to be activated? could the ios have to do with it?
You can check the router flash to see if this uck9 license file is present there. if yes, then use the procedure mentioned above to install it , else you can contact the Cisco TAC licensing team to verify if they can provide the license depending on how the license was ordered.
Manish
AG#show flash
-#- --length-- -----date/time------ path
1 2814 Aug 8 2012 08:37:12 +00:00 cpconfig-29xx.cfg
2 3000320 Aug 8 2012 08:37:26 +00:00 cpexpress.tar
3 1038 Aug 8 2012 08:37:34 +00:00 home.shtml
4 122880 Aug 8 2012 08:37:44 +00:00 home.tar
5 1697952 Aug 8 2012 08:38:00 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
6 415956 Aug 8 2012 08:38:12 +00:00 sslclient-win-1.1.4.176.pkg
7 98679236 May 27 2014 10:34:34 +00:00 c2900-universalk9-mz.SPA.154-2.T.bin
didnt find any .lic file  , there is no other possibility it could be there and need activation right?
I can't think of anything else. if you check with licensing team they can verify if your serial number for this router is entitled for these licenses or not, so just in case you lost/misplaced the licenses they can reissue the same if you are entitled.
Manish
I think when licenses are loaded after u generate them, then it shows in flash of router else when router comes pre-loaded with UC license from Cisco, it does not show lic files in show flash.
I checked on one of the 3945 router, it shows in flash since I generated them and loaded.
regds,
aman
