Showing results forĀ
Search instead forĀ
Did you mean:Ā
cant make international conference call on Cisco phone by putting conference code
amralrazzaz
Level 5
Level 5
hi
i have Cisco phones at office , my problem is i received a conference call we conference code by email as invitation
i dial the international number (Holland for example) normally and then the answer machine requesting me to put the conference code , so the local answer machine (Egypt) said this number is wrong please check number .etc
why i cant put the conference code to join the call and  the local answer machine reply this number is number and the international call is already on hold waiting for conference code to join
Note: i dont have landline , im using Vodafone sim card on our ip central system because we dont have landline infra and boxes in our building
thanks
amr alrazzaz
71 Replies 71
sorry for that how to capture buffer on this commands without enable the term mon , becuase there is no output appear during call ?
i put the following :
Router#debug voip hpi all
voip hpi all debugging is ON
Router#debug voip dspapi all
voip dspapi all debugging is ON
but how to capture buffer ?
please check attached may can help
amr alrazzaz
hi man
any update regarding my issue :)
thanks
amr alrazzaz
Can you please apply what follows to your config?
Under voice service voip
sip
 rel1xx disable
  min-se 3600
  registrar server
  asymmetric payload full
  early-offer forced
  midcall-signaling passthru
Than create a voice class codec as follows
voice class codec 10
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729br8
Apply this voice class to all your dialpeers and to all voice register pools
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
hi man thanks a lot for your reply just now i notice it .... is this for the international conference call on Cisco phone .... because my problem as u know just to remind u again after calling the number i have to put a conference code to join the meeting but the device not recognize its just a code it take it as number and then the local provider answer machine reply this number is invalid please try a valid number
amr alrazzaz
amr alrazzaz
dear plz check this msg
Router(config-class)#codec preference 3 g729br8
WARNING: This codec has built-in vad that cannot be disabled.
If this codec is negotiated the vad configuration will be disregarded.
also about codec g711alaw its not working on my devices (cp7821 and 7945) but any way i did what u said exactly and applied it on voice reg pools and dial-peer voice 2000 voip
is it okay or there is some thing else and here u r the config :
Router(config-class)#do sh run
Building configuration...
Current configuration : 14077 bytes
! Last configuration change at 13:50:50 UTC Mon Aug 13 2018 by amr
version 15.4
hostname Router
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 $1$l9ha$dHLj/scp8Qm8C77UcUa/K0
enable password cisco1
no aaa new-model
clock timezone UTC 2 0
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.2.207
ip dhcp pool voice
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.207
option 150 ip 192.168.2.207
dns-server 8.8.8.8 8.8.4.4
ip dhcp global-options
dns-server 163.121.128.134 163.121.128.135
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
trunk group Mobile
trunk group pstn
cts logging verbose
crypto pki trustpoint TP-self-signed-2728187941
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2728187941
revocation-check none
rsakeypair TP-self-signed-2728187941
crypto pki certificate chain TP-self-signed-2728187941
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32373238 31383739 3431301E 170D3135 30333231 31333235
31375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37323831
38373934 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C184 ACFFFB46 C4C5B385 CBE1A6C9 0CD5DA07 385B1D99 C8AD86D5 9CFAA109
CACAA786 2AE1D32F CC3AC285 BBA7B419 04B2482A 0B7DD955 99130F92 48B2A075
E8B170CA 230036B1 73D4F8FF 26E2B556 6FD337BE 3A8B341B 0A80C612 6737B714
96CFA520 995A0E45 993F558D 1DFC222A 3F587ABE E3E1F038 3CA3152F F0222271
00330203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14AEA7B2 0A72790D BDCE8BF7 9C2D6CF2 C1C8A393 5B301D06
03551D0E 04160414 AEA7B20A 72790DBD CE8BF79C 2D6CF2C1 C8A3935B 300D0609
2A864886 F70D0101 05050003 81810072 94945FF4 84A78DF0 CF361867 79566C0F
D6FB48FD 3ACB218F 800D5CA1 54F4F4E2 5ED04E26 4A5DC612 097EE5D0 5A26618A
80DB770F 30768D27 C5F7679A D5E81483 C3993CC4 15CFF495 39F11F9D 7EE9054D
DC5CDEEE B3E35F53 09DB553A EACEE590 D128A220 52EE5C32 FCA5A626 BDAD34D5
6DABFE4F F30D63A5 5C92E27A 7E3EE0
quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol pass-through g711ulaw
h323
sip
rel1xx disable
min-se 3600 session-expires 3600
registrar server
early-offer forced
voice register global
mode cme
source-address 192.168.2.207 port 5060
max-dn 64
max-pool 58
load 7821 sip78xx.12-1-1-12.loads
timezone 25
date-format D/M/Y
tftp-path flash:
create profile sync 0165464226868528
network-locale GB
voice register dn 1
voice register dn 5
number 100
name Inas AlMahalawi
label Inas AlMahalawi
mwi
voice register dn 6
number 101
name Meeting Room A
label Meeting Room A
mwi
voice register dn 7
number 102
call-forward b2bua noan 5 timeout 20
name Walid Hifny
auto-answer
label Walid Hifny
mwi
mobility
voice register dn 8
translation-profile incoming AMR
translation-profile outgoing AMRALRAZZAZ
number 103
name Amr Al-RaZzAz
auto-answer
label Amr Al-RaZzAz
mwi
mobility
voice register dn 9
number 104
name Khaled El Garhy
label Khaled El Garhy
mwi
voice register dn 10
number 105
name Sales 2
label Sales 2
mwi
voice register dn 11
number 107
name Amr Ismail
label Amr Ismail
mwi
voice register dn 12
number 108
name Mohammed Abdella
label Mohammed Abdella
mwi
voice register dn 13
number 109
name Sales 1
label Sales 1
mwi
voice register dn 14
number 110
name Karim Habib
label Karim Habib
mwi
voice register dn 15
number 114
name Tamer Mazen
label Tamer Mazen
mwi
voice register dn 16
number 115
name Meeting Room B
label Meeting Room B
mwi
voice register dn 17
number 106
name Conference Room
label Conference Room
mwi
voice register dn 18
number 112
name Omar Mohamed
label Omar Mohamed
mwi
voice register dn 19
number 113
name Tarek Aldessouky
label Tarek Aldessouky
mwi
mobility
voice register pool 5
busy-trigger-per-button 1
id mac 5067.AE21.4E6E
type 7821
number 1 dn 5
cor incoming mobile-long default
presence call-list
dtmf-relay rtp-nte
voice-class codec 10
username romani password cisco
voice register pool 6
pin 4100
id mac 5067.AE21.4EA5
type 7821
number 1 dn 6
presence call-list
dtmf-relay rtp-nte
voice register pool 7
id mac 5067.AE21.9A74
type 7821
number 1 dn 7
presence call-list
dtmf-relay rtp-nte
voice register pool 8
id mac 5067.AE21.9A5A
type 7821
number 1 dn 8
no digit collect kpml
presence call-list
dtmf-relay rtp-nte
voice register pool 9
id mac 5067.AE21.99AC
type 7821
number 1 dn 9
presence call-list
dtmf-relay rtp-nte
voice register pool 10
id mac 5067.AE21.9A52
type 7821
number 1 dn 10
presence call-list
dtmf-relay rtp-nte
voice register pool 11
id mac 5067.AE21.9A1D
type 7821
number 1 dn 11
presence call-list
dtmf-relay rtp-nte
voice register pool 12
id mac 5067.AE21.4F10
type 7821
number 1 dn 12
presence call-list
dtmf-relay rtp-nte
voice register pool 13
id mac 5067.AE21.4E15
type 7821
number 1 dn 13
presence call-list
dtmf-relay rtp-nte
voice register pool 14
id mac 5067.AE21.4DF7
type 7821
number 1 dn 14
presence call-list
dtmf-relay sip-kpml sip-notify
voice register pool 15
id mac 5067.AE21.4EAD
type 7821
number 1 dn 15
presence call-list
dtmf-relay rtp-nte
voice register pool 16
id mac 5067.AE21.4E9D
type 7821
number 1 dn 16
presence call-list
dtmf-relay rtp-nte
voice register pool 17
id mac 5067.AE21.4DD6
type 7821
number 1 dn 17
presence call-list
dtmf-relay rtp-nte
voice register pool 18
id mac 5067.AE21.4F96
type 7821
number 1 dn 18
presence call-list
dtmf-relay rtp-nte
voice register pool 19
id mac 5067.AE21.4F9C
type 7821
number 1 dn 19
presence call-list
dtmf-relay rtp-nte
no vad
license udi pid CISCO2911/K9 sn FCZ190360AM
license accept end user agreement
hw-module pvdm 0/0
username cisco password 0 cish:
username romani secret 5 $1$5Klr$GneBF.AwmAgvMY4lW/Ylk1
username aa
username Acc
username amr privilege 15 secret 9 $9$eSfWH2ACcyEpgU$kBe69JmDRjwR01pDNDUjBF
17G2JI8hOCafvoaptS8f6
redundancy
process-max-time 50
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.2.207 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 192.168.1.207 255.255.255.0
ip flow ingress
ip flow egress
ip nat outside
ip rip advertise 100
ip rip receive version 2
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
router rip
network 192.168.1.0
network 192.168.2.0
ip forward-protocol nd
ip http server
ip http secure-server
ip http path flash:
ip flow-export source GigabitEthernet0/0
ip flow-export version 9
ip flow-export destination 192.168.2.195 9996
ip flow-top-talkers
top 60
sort-by packets
ip dns view default
dns forwarder 8.8.8.8
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
snmp-server community public RO
tftp-server flash:cmterm-78xx.12-1-1-12/kern78xx.12-1-1-12.sbn alias kern78
xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs2.78xx.12-1-1-12.sbn alias ro
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs78xx.12-1-1-12.sbn alias root
tftp-server flash:cmterm-78xx.12-1-1-12/sboot2.78xx.12-1-1-12.sbn alias sbo
tftp-server flash:cmterm-78xx.12-1-1-12/sboot78xx.12-1-1-12.sbn alias sboot
78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sip78xx.12-1-1-12.loads alias sip78
xx.12-1-1-12.loads
tftp-server flash:cmterm-78xx.12-1-1-12/kern2.78xx.12-1-1-12.sbn alias kern
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
voice-port 0/0/0
trunk-group Mobile
cptone EG
connection plar opx 100
impedance complex2
description Configured by 2911 4 FXO-0/0/0-Custom
caller-id enable
caller-id alerting ring 2
voice-port 0/0/1
trunk-group Mobile
cptone EG
impedance complex2
description Configured by 2911 4 FXO-0/0/1-Custom
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
mgcp profile -long
dial-peer cor custom
name internal
name pstn
name long
name mobile
name international
dial-peer cor list internal
member internal
dial-peer cor list mobile-long
member internal
member pstn
member long
member mobile
dial-peer cor list manager
member internal
member pstn
member long
member mobile
member international
dial-peer voice 8 pots
trunkgroup long
trunkgroup Mobile
corlist outgoing mobile-long
destination-pattern 904......T
prefix 04
dial-peer voice 9 pots
trunkgroup long
trunkgroup Mobile
destination-pattern 905......T
prefix 05
dial-peer voice 22 pots
service stcapp
port 0/0/2
dial-peer voice 10 pots
trunkgroup long
trunkgroup Mobile
trunkgroup Inter
trunkgroup international
corlist outgoing manager
description **Cairo**
destination-pattern 900T
prefix 00
dial-peer voice 2 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
description **shortcut No**
destination-pattern 91[16789]...
forward-digits 5
dial-peer voice 3 pots
trunkgroup long
trunkgroup PSTN
description ** Services **
destination-pattern 91[1245].
forward-digits 3
prefix 013
dial-peer voice 7 pots
trunkgroup long
trunkgroup Mobile
description **Alex**
destination-pattern 903......T
prefix 03
dial-peer voice 15 pots
description ** Sedestination-pattern 9013.T
destination-pattern 402
b2bua
session protocol sipv2
voice-class codec 10 offer-all
dtmf-relay sip-notify
no vad
dial-peer voice 1 pots
trunkgroup pstn
trunkgroup Mobile
description ** Inside Cairo **
destination-pattern 902.......T
no digit-strip
forward-digits 8
prefix 02
no register e164
dial-peer voice 4 pots
trunkgroup Mobile
description ** Mobile **
destination-pattern 901[012]........
forward-digits 11
dial-peer voice 6 pots
trunkgroup long
trunkgroup Mobile
description **Kaluobia**
prefix 013
dial-peer voice 11 pots
trunkgroup long
trunkgroup Mobile
prefix 00
dial-peer voice 12 pots
prefix 00
dial-peer voice 21 pots
service stcapp
port 0/0/1
dial-peer voice 13 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
description **Vodafone**
destination-pattern 92[47].
forward-digits 3
dial-peer voice 5 pots
trunkgroup long
trunkgroup Mobile
description **sharm alsheikh**
destination-pattern 9069......T
prefix 069
presence
gatekeeper
shutdown
telephony-service
max-ephones 58
max-dn 64
ip source-address 192.168.2.207 port 2000
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.
do
time-zone 25
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name romani password cisco
web admin customer name romani1 password cisco
dn-webedit
time-webedit
transfer-system full-consult dss
create cnf-files version-stamp 7960 Jun 03 2018 17:11:36
ephone-dn 1 dual-line
number 111 no-reg primary
label 111
description Mr. Amr Ismaeil
name Mr. Amr Ismaeil
ephone 1
video
mac-address 1CE8.5DC8.D374
username "aa"
paging-dn 1
type 7945
button 1:1
pin 4100
ephone 2
ephone 5
line con 0
password
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
amr alrazzaz
also can i asked if we can add more codec under voice class codec ?
version 15.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool voice
import all
ip cef
no ipv6 cef
trunk group Mobile
trunk group pstn
cts logging verbose
quit
voice-card 0
voice service voip
h323
sip
rel1xx disable
registrar server
early-offer forced
mode cme
max-dn 64
max-pool 58
timezone 25
date-format D/M/Y
tftp-path flash:
network-locale GB
voice register dn 1
voice register dn 5
number 100
mwi
voice register dn 6
number 101
name Meeting Room A
mwi
voice register dn 7
number 102
name Walid Hifny
auto-answer
label Walid Hifny
mwi
mobility
voice register dn 8
number 103
name Amr Al-RaZzAz
auto-answer
label Amr Al-RaZzAz
mwi
mobility
voice register dn 9
number 104
mwi
number 105
name Sales 2
label Sales 2
mwi
number 107
name Amr Ismail
label Amr Ismail
mwi
number 108
mwi
number 109
name Sales 1
label Sales 1
mwi
number 110
name Karim Habib
label Karim Habib
mwi
number 114
name Tamer Mazen
label Tamer Mazen
mwi
number 115
name Meeting Room B
mwi
number 106
mwi
number 112
name Omar Mohamed
label Omar Mohamed
mwi
number 113
mwi
mobility
type 7821
number 1 dn 5
presence call-list
dtmf-relay rtp-nte
pin 4100
type 7821
number 1 dn 6
presence call-list
dtmf-relay rtp-nte
type 7821
number 1 dn 7
presence call-list
dtmf-relay rtp-nte
type 7821
number 1 dn 8
presence call-list
dtmf-relay rtp-nte
type 7821
number 1 dn 9
presence call-list
dtmf-relay rtp-nte
type 7821
number 1 dn 10
presence call-list
dtmf-relay rtp-nte
type 7821
number 1 dn 11
presence call-list
dtmf-relay rtp-nte
type 7821
number 1 dn 12
presence call-list
dtmf-relay rtp-nte
type 7821
number 1 dn 13
presence call-list
dtmf-relay rtp-nte
type 7821
number 1 dn 14
presence call-list
type 7821
number 1 dn 15
presence call-list
dtmf-relay rtp-nte
type 7821
number 1 dn 16
presence call-list
dtmf-relay rtp-nte
type 7821
number 1 dn 17
presence call-list
dtmf-relay rtp-nte
type 7821
number 1 dn 18
presence call-list
dtmf-relay rtp-nte
type 7821
number 1 dn 19
presence call-list
dtmf-relay rtp-nte
no vad
hw-module pvdm 0/0
username aa
username Acc
redundancy
process-max-time 50
no ip address
shutdown
ip flow ingress
ip flow egress
ip nat inside
duplex auto
speed auto
no mop enabled
ip flow ingress
ip flow egress
ip nat outside
duplex auto
speed auto
no ip address
duplex auto
speed auto
router rip
network 192.168.1.0
network 192.168.2.0
ip http server
ip http path flash:
ip flow-top-talkers
top 60
sort-by packets
ip dns view default
ip dns server
xx.12-1-1-12.sbn
78xx.12-1-1-12.sbn
xx.12-1-1-12.loads
control-plane
voice-port 0/0/0
trunk-group Mobile
cptone EG
timing guard-out 1000
impedance complex2
caller-id enable
voice-port 0/0/1
trunk-group Mobile
cptone EG
impedance complex2
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp profile -long
name internal
name pstn
name long
name mobile
name international
member internal
member internal
member pstn
member long
member mobile
member internal
member pstn
member long
member mobile
trunkgroup long
trunkgroup Mobile
prefix 04
trunkgroup long
trunkgroup Mobile
prefix 05
service stcapp
port 0/0/2
trunkgroup long
trunkgroup Mobile
trunkgroup Inter
prefix 00
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
forward-digits 5
trunkgroup long
trunkgroup PSTN
forward-digits 3
prefix 013
trunkgroup long
trunkgroup Mobile
prefix 03
b2bua
no vad
trunkgroup pstn
trunkgroup Mobile
no digit-strip
forward-digits 8
prefix 02
no register e164
trunkgroup Mobile
forward-digits 11
trunkgroup long
trunkgroup Mobile
prefix 013
trunkgroup long
trunkgroup Mobile
prefix 00
prefix 00
service stcapp
port 0/0/1
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
forward-digits 3
trunkgroup long
trunkgroup Mobile
prefix 069
presence
gatekeeper
shutdown
telephony-service
max-ephones 58
max-dn 64
do
time-zone 25
time-format 24
dn-webedit
time-webedit
label 111
ephone 1
video
username "aa"
paging-dn 1
type 7945
button 1:1
pin 4100
ephone 2
ephone 5
line con 0
password
login
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
transport input all
amr alrazzaz
hi all
could you please help me in my issue it still cant join conference call after put the conference code which requested from me after dialing the number of the meeting and the Cisco phone recognize the code as number and its like outing me from the original call and telecom vendor answer machine said it swrong number please dial correct one
amr alrazzaz
Can you open up a new thread for this please ? I lost track to what has been done etc etc since it has gone way too long.
Open up a new post, add the latest config and any recent logs only. Do not include previous logs. I will try and help you on this.
thanks alot engineer nipun :)
amr alrazzaz
amr alrazzaz
amr alrazzaz
