IP Communicator like there are no compatible sound Card
Ibrahim Jamil
Level 6
Level 6
Hi Freinds
I m getting errors when i start the IP Communicator like there are no compatible sound Card
Attached the error
thanks all
Chris Deren
Sounds like the Windows machine you are using does not have a sound card installed, does it?  You cannot run IPC without sound card.
R0g22
If you are trying to run this on a vm machine, you could install a proxy sound card which is just an application which mimics a
sound card. Apart from using the cipc for lab/learning purpose, not
much helpful in a production for end users.
Hi Mate
can y pls point me to proxy sound card name in order to download it and run it
Look for virtual audio cable. Search the forums here, there is a post somewhere around the installation.
