Cant upload cme file to 2691 router
John Cheetley
Level 3
Level 3
To the cisco techs out there for CME and FTP,
Using FileZilla server FTP to transfer 50mb tar file to router gets error below
(No such file or directory)
If I transfer a 70mb similar file to router, from same c:\ location, the file transfers via FTP to router but runs out of space so that is ok.(just for testing)
This 70mb file is in same location as 50mb file. Using same compression tool, winzip
If I use winrar. Same result. (no such file or directory)
Any ideas are welcome
paolo bevilacqua
You don't need or are supposed to transfer the whole tarfile.
Only individual files according the the specific needs, in most cases none is needed.
Thanks Paulo again for your input
Why is this topic so regulated. Havent been able to find much on this at all?
Just want to load cme onto router and other associated files.
My employer has enrolled me into ICND 1 & 2 but re configuring..not much on the internet unless I am searching for the wrong information?
