11-05-2024 02:22 AM
Hallo,
I have a Catalyst 1300 that I want to use as an access switch for some telephones and APs. I have followed the config guide but the telephone is not getting an IP address from our DHCP server. The voice vlan has been set and the interface configured as below:
Test-999CI1300#sh voice vlan
Administrate Voice VLAN state is auto-enabled
Operational Voice VLAN state is auto-enabled
Best Local Voice VLAN-ID is 251
Best Local VPT is 5 (default)
Best Local DSCP is 46 (default)
Agreed Voice VLAN is received from switch 84:5a:3e:90:1f:62
Agreed Voice VLAN priority is 0 (active static source)
Agreed Voice VLAN-ID is 251
Agreed VPT is 5
Agreed DSCP is 46
Agreed Voice VLAN Last Change is 24-Oct-24 00:05:17
Test-999CI1300#sh run int g1
interface GigabitEthernet1
spanning-tree portfast
switchport access vlan 251
Test-999CI1300#ping 172.x.x.x ---------------------> ping to the distribution switch where voice SVI is works
Pinging 172.x.x.x with 18 bytes of data:
18 bytes from 172.x.x.x: icmp_seq=1. time=0 ms
18 bytes from 172.x.x.x: icmp_seq=2. time=0 ms
18 bytes from 172.x.x.x: icmp_seq=3. time=0 ms
18 bytes from 172.x.x.x: icmp_seq=4. time=0 ms
----172.x.x.x PING Statistics----
4 packets transmitted, 4 packets received, 0% packet loss
round-trip (ms) min/avg/max = 0/0/0
Could I be missing any config? I'll appreciate your input.
11-05-2024 03:25 AM
Have you set the IP helper on the VLAN interface?
11-05-2024 04:06 AM
Hallo @Roger Kallberg. That is already configured on the ISR1100 router and the voice vlan to the dhcp and it can be pinged.
11-05-2024 04:26 AM - edited 11-05-2024 04:26 AM
Please share your running configuration so that we can verify it.
11-05-2024 04:47 AM
You have only configured switchport access vlan 251
, but for the phone to get an IP from the voice VLAN, you need the command switchport voice vlan 251
. I’m not sure how to configure that on the C1300, but this is how it works on other Cisco models.
11-05-2024 05:07 AM - edited 11-05-2024 05:07 AM
@Nithin Eluvathingal C1300 configs are different, so that is for any other switch but the C1200 and C1300
@Roger Kallberg Here are the configs:
config-file-header
Test-999CI1300
v4.0.0.93 / RLSB4.0HF_950_778_052
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
unit-type-control-start
unit-type unit 1 network gi uplink none
unit-type-control-end
udld aggressive
spanning-tree mode rapid-pvst
vlan database
vlan 100,251,300,804-806
exit
voice vlan id 251
voice vlan state auto-enabled
voice vlan oui-table add 0001e3 Siemens_AG_phone
voice vlan oui-table add 00036b Cisco_phone
voice vlan oui-table add 00096e Avaya
voice vlan oui-table add 000fe2 H3C_Aolynk
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone
voice vlan oui-table add 00e075 Polycom/Veritel_phone
voice vlan oui-table add 00e0bb 3Com_phone
errdisable recovery cause loopback-detection
errdisable recovery cause udld
errdisable recovery cause storm-control
bonjour interface range vlan 1
hostname Test-999CI1300
aaa authentication login tacacs local
ip http timeout-policy 300
ip https logging enable
no ip domain lookup
ip domain name abcTest
interface vlan 100
name INTRANET
interface vlan 251
name VOICE
interface vlan 300
name WLAN
interface vlan 804
name GLT
interface vlan 805
name MGMT
ip address 172.x.x.x
no ip proxy-arp
interface vlan 806
name AP-MGMT
interface GigabitEthernet17
switchport mode trunk
switchport trunk native vlan 806
switchport trunk allowed vlan 300,806
-------------truncated-------------
interface GigabitEthernet24
switchport trunk allowed vlan 100,251,300,804-806
interface GigabitEthernet25
shutdown
interface Port-Channel1
shutdown
exit
ip dhcp snooping
ip dhcp snooping vlan 100
ip dhcp snooping vlan 251
ip dhcp snooping vlan 300
ip dhcp snooping vlan 806
ip default-gateway 172.30.x.x
Test-999CI1300#
02-24-2025 12:04 AM
I'm having the same issue. May I know any solution?
