cause 1 = 0x82A6 Network out of order - ISDN error
When we are try to make outgoing call, we are getting the below error :
Incoming call there is no problem in the Same E1 PRI line, ISP saying there is no problem from thier side.
9 Replies 9
Manish Prasad
Level 5
Level 5
VOIP Interface binding in place ? Can you share your config ?
Manish
Which gateway protocol you are using ?
Please share your call flow topology?
Share your running config and "debug isdn q931" from your VG.
Nishant Savalia
Regards, Nishant Savalia
We are using h323 gateway. When I am using csim start the outgoing calls fails
ISA-VG1#un all
All possible debugging has been turned off
ISA-VG1#csim start 93XXX6306
csim: called number = 93XXX6306, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(570049)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
Router#sh gateway
H.323 ITU-T Version: 4.0   H323 Stack Version: 0.1
H.323 service is up
This gateway  is not registered to any gatekeeper
Alias list (CLI configured) is empty
Alias list (last RCF) is empty
csim: called number = 934466306, loop count = 1 ping count = 0
*Feb  5 13:06:47.949 UTC: ISDN Se0/3/0:15 Q931: Sending SETUP  callref = 0x3957
callID = 0xCE73 switch = primary-net5 interface = User
*Feb  5 13:06:47.953 UTC: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8  callref = 0x
3957
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Called Party Number i = 0x80, '34XXX6306'
                Plan:Unknown, Type:Unknown
*Feb  5 13:06:48.049 UTC: ISDN Se0/3/0:15 Q931: RX <- SETUP_ACK pd = 8  callref
= 0xB957
csim err csimDisconnected recvd DISC cid(570048)
ISA-VG1#
*Feb  5 13:06:48.049 UTC: ISDN Se0/3/0:15 Q931: RX <- CALL_PROC pd = 8  callref
= 0xB957
        Progress Ind i = 0x8288 - In-band info or appropriate now available
*Feb  5 13:06:48.097 UTC: ISDN Se0/3/0:15 Q931: RX <- RELEASE pd = 8  callref =
0xB957
       Cause i = 0x82A6 - Network out of order
*Feb  5 13:06:48.097 UTC: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callr
ef = 0x3957
Incoming calls are perefect, Please let me know the problem is from ISP Side ?
From the debug it seems that problem is from ISP side because they are sending disconnect message.
But before that make sure from your side that all the information sent from your side in "call setup message" is correct .
And as you are receiving cause code " Network out of order" which probably is the issue from ISP side.
Also test by dialing some other number, if you are receiving this cause code for all the calls.
Nishant Savalia
Please let me know how to check Call setup message is correct ?
To check the call setup message, three basic things you have to keep in mind
1). Calling & Called party required digits
2). Calling & Called party plan type
3). Channel number to which call is sent.
Nishant Savalia
I had the same issue and voip interface binding was the fix for it.
Could you please post the complete 'debug isdn q931' logs for a test call?
Cause Code Origination Point: 82—the public network near the local user (local telco switch)
A6Network out of order The destination is not reachable because of a network                 malfunction. The condition can last for an extended period. An immediate                 attempt to reconnect will probably fail.               If you use a long distance carrier, try to use a Presubscribed                 Inter-exchange Carrier (PIC). For example, you can use a 10-10-xyz carrier. A                 PIC enables you to verify whether the problem lies with the long distance                 carrier.
ISDN Diconnect Cause codes URL for your reference:
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
If you receive this disconnect cause: cause 1 = 0x82A6 from Provider, then you should provide the isdn logs to them and ask them to verify it again on why they are disconnecting the call.
Please rate all the useful posts
//Suresh Please rate all the useful posts.
Thiago Almeida
It is a Network problem!! Check the network connect and the dial-peer voip IP Address.
Thiago Almeida
