CCM 5.04 with H.323 gateway ringback tone question
etmarcof
Level 3
Level 3
I have configured in CCM an Ericsson H.323 gateway (for use Ericsson DECT Phones) when an Ericsson phone calls to an Cisco IP phone i don't hear ringback tone, but if ip phone is busy i hear busytone. From cisco ip phone to Ericsson phone its ok.
Can i setup something in CCM to force ringback tone when Ericsson phone calls to cisco ip phone??
Best Regards.
MC
5 Replies 5
dsweeny
Level 3
Level 3
Is this problem associated only with Ericsson DECT phones associated with cisco ip phones? Configure the Ciso IOS command progress_ind setup enable 3 under the voice dial-peer# voip command in the Cisco gateway.
I have done that, yet.
For external calls (calls to PSTN) calls from DECT phones goes through cisco GW and i don't have that problem. Only for internal calls from Ericsson DECT phone to cisco IP phones. In that case calls don't go through cisco gateway so i don't ear ringback tone, but if ip phone is busy i ear busy tone.
BR,
MC
jgross
I think i have to change Send h225 user info message in CCM service parameter,
what would be better
User info h225 or h225 info or ANN? Do i have to restart CCM service after change?
BR,
MC
mzik
I would like to set-up an Ericsson switch (MX-ONE Telephony switch, currently distributed under AASTRA brand) as a H.323 gw in CUCM 6.1.2. Unfortunatelly I failed in this. Would you be willing to share some experience?
Thank you.
Mirek
