CCM and CCX upgrade via PCD
W S H FERNANDO
Level 4
Level 4
Hi All
I have a CCM cluster which running on version 7.1 and CCX which running on version 8.
I need to upgrade both of these to version 10.5.2. I have experience with upgrading CCM 7.1 to 10.5 with PCD. but I don't have experience upgrade CCX with PCD.
My question is whether PCD supporting upgrade of CCX 8.x to 10.5 ?
or that is a manual upgrade process ?
If you have any documentation please share..
Regds
2 Accepted Solutions
Jaime Valencia
We should start by the fact that an upgrade, IS NOT the same as a migration in PCD.
PCD MIGRATES versions 6.x and 7.x, NOT upgrades them.
also, the PCD documentation already covers what products PCD is compatible with, and what it can do with them (install, upgrade, migrate, re-address, etc)
java
if this helps, please rate
Chris Deren
The PCD features chapter for PCD admin guide documents all supported upgrade, migration, install, etc tasks per application that can be done with that version of PCD.  Here is link to PCD 11.0 guide:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/pcdadmin/11_0_1/CUCM_BK_PB6D9005_00_pcd-administration-guide-110/CUCM_BK_PB6D9005_00_pcd-administration-guide-110_chapter_011.html
Jaime Valencia
java
Chris Deren
