CCM4.3(2) upgrade to BE6000 - phone firmware problems?
torleif
We want to upgrade from CCM 4.3(2) to BE6000.
Is it possible to upgrade directly from 4.3(2) to BE6000?
Someone claims there is a problem upgrading phone firmware from CCM4.3(2) to BE6000. Is this correct?
Torleif
Tjome Municipality, Norway
6 Replies 6
Hi.
It depends on actual firmware version installed on your phones.
If you have a firmware version earlier than  8.3(3), you have first upgrade to firmware version 8.5(2) before you can upgrade to 9.1
Carlo
Please rate all helpful posts
Please rate all helpful posts "The more you help the more you learn"
Is it possible to use firmware 8.5(2) with ccm4.3(2)?
Torleif
Please refer the URL
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_2/english/release/notes/7900_852SR1.html
isco Unified IP Phone
Protocol
Cisco Unified Communications Manager
Cisco Unified IP Phone 7975G, 7965G, 7962G, 7945G, and 7942G
SCCP
Cisco Unified Communications Manager 6.0 and later, Cisco Unified CallManager 5.1, 4.3, 4.2, and 4.1
SIP
Cisco Unified IP Phone 7971G-GE, 7970G, 7961G-GE, 7961G, 7941G-GE, 7941G, 7911G, and 7906G
SCCP
Cisco Unified Communications Manager 6.0 and later, Cisco Unified CallManager 5.1, 5.0, 4.3, 4.2, 4.1, 4.0, and Cisco CallManager 3.3
SIP
Cisco Unified Communications Manager 6.0 and later, Cisco Unified CallManager 5.1 and 5.0
Cisco Unified IP Phone 7931G
SCCP
Cisco Unified Communications Manager 7.1, 7.0, 6.0 and 6.1
SIP
Cisco Unified Communications Manager 7.0 and later
Cisco Unified Expansion Module 7916
SCCP and SIP
Cisco Unified Communications Manager 6.1 and later
Cisco Unified Expansion Module 7915
SCCP and SIP
Cisco Unified Expansion Module 7914
SCCP and SIP
Cisco Unified Communications Manager 7.1 and earlier
For BE6000, u require UCS C220 M3 platform.
regds,
aman
I can also suggest you, to upgrade your phone firmware to the latest available version per model in order to avoid issues when you'll migrate to 9.1
Carlo
torleif
Thank you all for your replies!
I will start with making sure I have the latest CCM 4.3 firmware.
It seems like my 7960 havs firmware version 8.1(2.0). I am not sure if there is a newer version availible for CCM4.3.
Torleif
You can download cmterm-7940-7960-sccp.8-1-2SR2.exe from below link which is the latest available
http://software.cisco.com/download/release.html?mdfid=268437898&flowid=5246&softwareid=282074289&release=8.1(2)_SR2&relind=AVAILABLE&rellifecycle=&reltype=all
regds,
aman
