03-11-2015 06:41 AM - edited 03-17-2019 02:17 AM
I have problem with analog line which is connected to voice port 0/1/0. Outgoing calls working fine, but when somebody is calling from outside there is normal ringing sound but none of telepfones is ringing, problem is with number 0618181143. Part of router configuration:
stcapp ccm-group 2
stcapp feature access-code
isdn switch-type basic-net3
password encryption aes
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol cisco
sip
no update-callerid
sip-profiles 100
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class sip-profiles 100
request INVITE sip-header From modify "(<.*:)(.*@)" "<sip:xxx@"
request INVITE sip-header Remote-Party-ID remove
request CANCEL sip-header From modify "(<.*:)(.*@)" "<sip:xxx@"
voice register global
max-dn 56
max-pool 14
voice translation-rule 4
rule 1 /5990/ /101/
voice translation-rule 5
rule 1 /5995/ /101/
voice translation-rule 1111
rule 1 /^1../ /0618975990/
rule 2 /^1../ /0618975095/
voice translation-rule 1112
rule 1 /^9\(.*\)/ /\1/
rule 2 /^9\(.*\)/ /\2/
voice translation-rule 2001
rule 1 /0618975095/ /101/
voice translation-rule 2010
rule 1 /^100/ /0618181143/
rule 2 /^101/ /0618181143/
rule 3 /^102/ /0618181143/
rule 4 /^103/ /0618181143/
rule 5 /^104/ /0618181143/
rule 6 /^105/ /0618181143/
rule 7 /^106/ /0618181143/
rule 8 /^107/ /0618181143/
voice translation-profile AA_Profile
translate called 2001
voice translation-profile Biuro_Called_5
translate called 5
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile FROMSIP
translate calling 5
translate called 3
voice translation-profile Fax_Called_4
translate called 4
voice translation-profile IN_Profile
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile TOSIP
translate calling 1
translate called 2
voice translation-profile to_analog_1143
translate calling 2010
voice-card 0
interface FastEthernet0/1.1
description $FW_INSIDE$
encapsulation dot1Q 1 native
ip address 192.168.0.2 255.255.255.0
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
interface FastEthernet0/1.100
encapsulation dot1Q 100
ip address 10.10.0.1 255.255.255.0
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface BRI0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
isdn point-to-point-setup
interface BRI0/1/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
ip local pool SDM_POOL_1 192.168.99.1 192.168.99.20
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.3
ip http server
ip http authentication local
ip http secure-server
ip http path flash:
ip access-list extended tunnel2
deny ip any any log
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 2 remark Auto generated by SDM Management Access feature
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 192.168.20.0 0.0.0.255
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 106 remark Auto generated by SDM Management Access feature
access-list 106 remark SDM_ACL Category=1
access-list 106 permit ip 192.168.20.0 0.0.0.255 any
access-list 106 permit ip 192.168.0.0 0.0.0.255 any
route-map SDM_RMAP_1 permit 1
match ip address 103
tftp-server flash:cnu75.8-3-1-22.sbn
tftp-server flash:cvm42sccp.8-3-1-22.sbn
tftp-server flash:cvm45sccp.8-3-1-22.sbn
tftp-server flash:cvm75sccp.8-3-1-22.sbn
tftp-server flash:dsp42.8-3-1-22.sbn
tftp-server flash:dsp45.8-3-1-22.sbn
tftp-server flash:dsp75.8-3-1-22.sbn
tftp-server flash:jar42sccp.8-3-1-22.sbn
tftp-server flash:jar45sccp.8-3-1-22.sbn
tftp-server flash:jar75sccp.8-3-1-22.sbn
tftp-server flash:term42.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:term75.default.loads
tftp-server flash:APPS-1.0.4.SBN
tftp-server flash:CP7921G-1.0.4.LOADS
tftp-server flash:GUI-1.0.4.SBN
tftp-server flash:SYS-1.0.4.SBN
tftp-server flash:TNUX-1.0.4.SBN
tftp-server flash:TNUXR-1.0.4.SBN
tftp-server flash:WLAN-1.0.4.SBN
tftp-server DistinctiveRingList.xml
tftp-server RingList.xml
tftp-server flash:AreYouThereF.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Chime.raw
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server S00105000100.sbn
tftp-server flash:cmterm_7920.4.0-02-00.bin
tftp-server flash:apps41.8-4-1-23.sbn
tftp-server flash:cnu41.8-4-1-23.sbn
tftp-server flash:cvm41sccp.8-4-1-23.sbn
tftp-server flash:dsp41.8-4-1-23.sbn
tftp-server flash:jar41sccp.8-4-1-23.sbn
tftp-server flash:SCCP41.8-4-2S.loads
tftp-server flash:apps11.8-4-1-23.sbn
tftp-server flash:cnu11.8-4-1-23.sbn
tftp-server flash:cvm11sccp.8-4-1-23.sbn
tftp-server flash:dsp11.8-4-1-23.sbn
tftp-server flash:jar11sccp.8-4-1-23.sbn
tftp-server flash:SCCP11.8-4-2S.loads
tftp-server flash:term61.default.loads
tftp-server flash:term41.default.loads
radius-server host 192.168.0.11 auth-port 1645 acct-port 1646 key 7 094E411B120A00010005
control-plane
voice-port 0/0/0
compand-type a-law
cptone PL
timeouts ringing infinity
description FAX
station-id name FAX
station-id number 108
caller-id enable
voice-port 0/0/1
compand-type a-law
cptone PL
description Magazyn
station-id name Magazyn
station-id number 107
caller-id enable
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
compand-type a-law
cptone PL
connection plar opx 100
description FXOport0
voice-port 0/2/1
compand-type a-law
cptone PL
connection plar 200
description FXOport1
caller-id enable
voice-port 0/2/2
compand-type a-law
cptone PL
connection plar 200
description FXOport2
caller-id enable
voice-port 0/2/3
compand-type a-law
cptone PL
connection plar opx 200
description FXOport3
caller-id enable
mgcp fax t38 ecm
sccp ccm 10.10.0.1 identifier 2 version 4.0
sccp ccm group 2
associate ccm 2 priority 1
dial-peer cor custom
name international
dial-peer cor list call-international
member international
dial-peer voice 3001 voip
destination-pattern 3..
session protocol sipv2
session target ipv4:192.168.30.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2 pots
destination-pattern 108
port 0/0/0
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number .%
direct-inward-dial
port 0/1/0
dial-peer voice 51 pots
direct-inward-dial
port 0/1/1
dial-peer voice 53 pots
description ** BRI pots dial-peer **
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 910T
port 0/1/0
prefix 10
no sip-register
dial-peer voice 54 pots
corlist outgoing call-international
preference 5
destination-pattern 912T
port 0/1/0
prefix 12
no sip-register
dial-peer voice 55 pots
description ** BRI pots dial-peer **-Emergency dial-peer
preference 5
destination-pattern 9112
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 56 pots
preference 5
destination-pattern 112
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 11 pots
translation-profile outgoing to_analog_1143
destination-pattern 9T
port 0/2/0
dial-peer voice 10 pots
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
port 0/1/0
dial-peer voice 1 pots
destination-pattern 107
port 0/0/1
dial-peer voice 12 pots
destination-pattern 8...
port 0/2/1
forward-digits 4
dial-peer voice 13 pots
port 0/2/2
dial-peer voice 14 pots
port 0/2/3
telephony-service
video
em logout 0:0 0:0 0:0
max-ephones 36
max-dn 100
ip source-address 10.10.0.1 port 2000
auto assign 10 to 19
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message Borkowski - Gwiazdzista
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
load 7914 S00105000300
load 7911 SCCP11.8-4-2S
load 7961 SCCP41.8-4-2S
load 7961GE SCCP41.8-4-2S
time-zone 23
time-format 24
date-format dd-mm-yy
voicemail 222
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh vivaldi.au
multicast moh 239.10.16.16 port 2000
web admin system name admin secret 5 $1$02Lp$hrXGO0/qAD9vTsB5YyNUU0
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp 7960 Dec 10 2009 22:07:58
ephone-dn 35 dual-line
number 101 no-reg primary
label 101 G.Hofman
description G.Hofman
name G.Hofman
call-forward all 102
huntstop channel
no huntstop
hold-alert 30 originator
ephone-dn 36 dual-line
number 102 no-reg primary
label 102 A.Nowacki
description A.Nowacki
name A.Nowacki
huntstop channel
no huntstop
ephone-dn 37 dual-line
number 103 no-reg primary
label 103 M.Pospieszna
description M.Pospieszna
name M.Pospieszna
huntstop channel
no huntstop
ephone-hunt 1 sequential
pilot 100 secondary 1143
list 102, 103, 101
preference 0 secondary 7
timeout 20, 20, 20
I'm quite newbie with voice staff and I don't know how to analyze this issue. Please help
03-11-2015 07:35 AM
You have some misunderstandings here...from your config we see that:
- you mean that voice port 0/2/0 is problem and not 0/1/0 - because you have plar 100 there;
- you have SIP trunk in your config - using with some provider I suppose;
- You have FXO lines there and one of them is PLAR-ed to extension 100 (which is hunt pilot btw so extensions 102,103 and 101 should ring) - what's the PSTN number of that FXO line? Can you try calling that number and see if extension 100 is ringing?
BR,
Dragan
03-12-2015 01:18 AM
Number is 0618181143. Nothing is ringing but I'm hearing normal calling sound in handset.
03-12-2015 07:44 AM
Please first try to connect the analog phone to that specific port and then test the incoming call.
Raaj
03-13-2015 01:09 AM
I'm not in that location. There was technician from company which provide analog line and he said that analog telephone is working. One question (maybe stupid), when I shutdown voice port 0/2/0 I shouldn't hear ringing sound?
03-13-2015 07:27 AM
If you shutdown that port and call PSTN number on that FXO port - you shouldn't hear ringing sound.
Maybe you shutdown that port but call SIP trunk number :)
BR,
Dragan
03-13-2015 07:57 AM
I shut down voice port and voice vlan and its ringing. Probably somebody did some mess in cables...
03-14-2015 08:27 AM
Please run the debug vpm signal command and check whether you really able to make outgoing call from that specific port by shutting other fxo ports.
If yes then check for incoming call, try to call multiple times to that number if it's a hunting line from ISP.
If still the issue persist then call check with analog phone, based on that check with ISP for the issue.
Raaj.
03-16-2015 03:22 AM
Thanks for help.
Problem is with fxo port, it isn't working.
03-11-2015 01:08 PM
Are ephone-dn's 35, 36, 37 assigned to an ephone? I don't see that part of the config.
Port 0/1/0 is a BRI port that is shut down, do you mean port 0/2/0? Does number 0618181143 point to 0/2/0?
03-12-2015 01:15 AM
Yes dn's are assigned and telephones are registered. Ofcourse I made mistake with port. Voice port 0/2/0 is pointed to extension 100 which is pilot for hunt group.
03-12-2015 07:28 AM
If you dial 100 from a registered phone does the hunt group work and ring extensions 101, 102, 103?
Have you tried changing the connection plar for 0/2/0 to a DN on a registered phone to take any hunt group issues out of the equation?
Do the other FX0 ports work when dialing in? If you call into 0/2/1, 0/2/2, 0/2/3 does it ring extension 200?
Verify the call is coming into 0/2/0 using:
show voice port summary
debug voip ccapi inout
Could also plug an analog phone into the cable going to 0/2/0. (Connect phone to the wire from the phone company, not to the port on the router).
