02-28-2014 06:16 PM - edited 03-16-2019 09:58 PM
hi All,
We have an ISR2911 CCME10 with 2x FXO port.
We are currently staging it, however we do not have FXO lines to test in house if our dial-peer plans is actually routed correct to our voice port 0/0/0 and voice port 0/0/1.
Is there a way,cmd i can test call from my ip phone and see if the call is routed out to the intended voice FXO port
please advise
03-01-2014 05:20 AM
I think you will need another router with 2x FXS port to test properly.
thanks
John
03-01-2014 10:00 AM
Hi.
You have different ways to test it.
debugging ccapi inout it will show you the matched outgoing dialpeer .
With debug vpm signal the output should show the port status progress.
Without a phone, from telnet or console session (not ssh) you can use the hidden command csim start followed by the number to dial.
Carlo
