CCME test call FXO without line
J_Vansen_S
Level 3
Level 3
hi All,
We have an ISR2911 CCME10 with 2x FXO port.
We are currently staging it, however we do not have FXO lines to test in house if our dial-peer plans is actually routed correct to our voice port 0/0/0 and voice port 0/0/1.
Is there a way,cmd i can test call from my ip phone and see if the call is routed out to the intended voice FXO port
please advise
johnd2310
Level 8
Level 8
I think you will need another router with 2x FXS port to test properly.
thanks
John
**Please rate posts you find helpful**
Hi.
You have different ways to test it.
debugging ccapi inout it will show you the matched outgoing dialpeer .
With debug vpm signal the output should show the port status progress.
Without a phone, from telnet or console session (not ssh) you can use the hidden command csim start followed by the number to dial.
Carlo
Please rate all helpful posts "The more you help the more you learn"
