CCME Transfer and conferencing problem.
Ayodeji Okanlawon
Guys,
I have an interesting problem on CCME 7.1.
There are 2 sites. One is CCME 7.1(remote) and the other CM7.1.3.(HQ)
Users dial between site over the PSTN. A 4 digit extension is dialled whihc is then xlated using the full DDI of the number.
The problem is this, each time a user attempts to trasfer a call to the head office (CCM) using the 4 digit extension (which is xlated to the full DDI), the xfer fails.
When an adhoc conference is also attempted, it fails "cannot complete conference".
When both scenarios are attempted using the full DDI, which does not go through the xlation pattern it works succesfully. Which meant tha my proble is with the xlation pattern
here is my dial-peer for the 4 digit number
dial-peer voice 9998 voip
incoming called-number .
dial-peer voice 100 voip
translation-profile outgoing Marlow
destination-pattern 3[147]..
session target ipv4:172.16.7.20
Do I need to enable some form of supplemenatry service on this dial-peer. ??
Please rate all useful posts
Steven Holl
That scenario may be working if the full DID number routes the call out a local PSTN circuit.  That changes the call topology enough for it to potentially work.  I'd take that test with a grain of salt.  Dial-peer/xlation issues wouldn't cause 'Cannot complete conference' on the phone.
First, since you are going to CM, make sure you have h450.2 (call transfer) and h450.3 (diversion) disabled on CME, since IOS enabled it by defaulyt but CM doesn't support it.  Also, enable ECS since that's how CM renegotiates media streams on hold/resume/transfer scenarios.  Do these and retest before continuing:
voice service voip
no supp h450.2
no supp h450.3
h323
  emptycapability
Assuming it is the CME phone hitting transfer/conference: how are you configured for conferencing on CME?  HW or SW?  Can you post:
sh run | s sccp|tele|ccm|dsp|voice
sh sccp
sh voice dsp group all
Note that conferences across the WAN will fail if you are using SW conferencing because that only supports g711.  If you want to use g729, you'll need to configure hardware ad-hoc conferencing and put g729 under the dspfarm profile.  Consult the CME Administration Guide for a sample config on that.  You may want to try configuring peers 9998 and 100 for 'codec g711ulaw' just to see if your tests work when using g711ulaw, though.
Also, it isn't causing this issue, but (for best practices and proper configuration) you're missing a DTMF relay configuration and you likely want to disable VAD, too; add:
  no vad
dtmf-relay h245-alpha
no vad
If you still have issues, post that output I requested, and collect the following for a failure:
debug voip ccapi inout
debug sccp all
debug cch323 all
debug h225 asn1
debug h245 asn1
Collect via:
Router(config)# service sequence
Router(config)# service timestamps debug datetime msec
Router(config)# logging buffered 10000000 7
Router(config)# no logging con
Router(config)# no logging mon
Router(config)# voice iec syslog
Router# term len 0
Router# sh logg
5 Replies 5
Steven Holl
voice service voip
no supp h450.2
no supp h450.3
h323
  emptycapability
sh sccp
  no vad
no vad
debug sccp all
debug cch323 all
debug h225 asn1
debug h245 asn1
Collect via:
Router# term len 0
Router# sh logg
Steven,
Thanks for posting this!!!  I was having an issue with Conferencing on CME 7.1 and could not figure it out.  I added the no supp 450.2 and no supp 450.3 commands and now everything works for me.
Thanks!!
Steve,
Thanks for your reply. Today I got a chance to work on this. I added the configs you suggested, but we keep getting cannnot complete conference. I was not able to take the debugs you ask for. I will do tomorrow and post them.
I will send the full CCMe config tomorrow and yes its software conferencing. I am not doing this over the WAN.
The scenario is this..CCME>>PSTN>CCM
So the call to CCM goes over the PSTN.
Steve,
It finally worked. When I looked at the logs, I saw that it was trying to use G.729 for the conferencing. Since I am using software conferencing, I changed it to G.711. what I do not get is this..I do not see any cause in the logs showing that it was codec issue. It just says cause=16. Just for learning purposes, can you help me look through the logs and let me know where I could have spotted the codec was causing the issue.
I did configure voice-class codec with g.711 and g.729. I thought this will enable codec negotiation if G.729 is not supported, obviuosly this was not the case.
Th call details:
Calling number :(4119) full ANI:01612723119
called number: 07967464902
Conference to number:  (3733) xlated to 01628403733
The first disconnect for the call is here:
362794: Nov 17 09:16:47.287: //119552/19809424AE74/CCAPI/cc_api_call_disconnected:
--More--                              Cause Value=16, Interface=0x49DB09AC, Call Id=119552
Leg 119552 is the CME leg.  You see cause value 16 on that leg because the conference not completing isn't the cause of the disconnect--it is just displaying an error on the phone at that point.  The user is hanging up after they see that message, which is the true disconnect of the call.
You would need to look at ephone detail and SCCP debugs to see the logic for the codec causing the conference bridge to not allocate if you wanted to see debugs pointing to it being the codec issue.
