ccmuser page logoff failure
telefonie
Level 5
Level 5
Hello
we run a CM cluster with 4.2(3).
When I log off the ccmuser page I always get a HTTP 500 error message (HTTP 500 - Internal server error) instead of beeing redirected to the logon page. All functions in the ccmuser interface work.
Any ideas???
Thanks Reto
8 Replies 8
gogasca
Level 10
Level 10
I had a similar case before and Callmanager users were using Internet Explorer version 7 for accessing the ccmuser page.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/sys_ad/4_1_3/ccmcfg/b01intro.htm#wp1027414
Use any of the following browsers: Internet Explorer 5 or 6, or Netscape Communicator versions 4.X.
Thanks for your response.
We use still IE 6.0 on our PCs and have this problem.
Any other ideas??
Thanks for help
Reto
What ES/SR are you currently running ?
Looks like this is a new Bug
we run 4.2(3)sr2b.
Reto
Ok, yes. I was able to re-create this in my lab as well. This for sure looks like a big and I've seen a few emails floating within cisco as of now. As of now there is no resolution found for it now do I have a Bug ID for the same. I'm sure something should be filed within the coming week . As of now there is no fix for this.
Is there a solution around for the logoff failure on the ccmuser web interface?
Thanks for feedback
Reto
Yes, there is a solution available for this. You will have to open a TAC case to get a new logoff.asp file to fix the issue
Do you happen to have the bug id for this?
