CCNA Voice Collaboration LAB
mekeniabe
Community Member
I bought a a Voice-enabled Cisco 2821 ISR Router for my Cisco CCNA Voice Collaboration LAB loaded with Cisco Unified CUCME/CME 8.6 (Call Manager Express) and CCP 2.7.IOS version is Mainline 15.1.4.M10 Adv. Enterprise Services (c2800nm-adventerprisek9-mz.151-4.M10.bin)
This Router includes the following Voice Cards and Modules:
- FXO Analog Card (needed to make Phone Calls outside the LAN)
- FXS Analog Card (needed to connect an Analog Phone)
- PVDM2 Module (needed to enable both Voice Cards)
I got everything working with my LAN Switch creating a LAN-based Phone Network.
All configurations for Inbound and Outbound Rule are all working.
The "connection" command for the Inbound Rule specifies a private-line, automatic ring doqwn (PLAR) connection, off premise connection (OPX) and to forward the incoming call from PSTN to the extension number say 2001.
In other words, if someone is calling my PSTN Phone number at home say 415-810-2907, the call is forwarded to extension 2001.
Is it possible for a single PSTN line ( not a DID trunk ) since this is just for Lab PURPOSES to call the extension number directly without dialing the the 415-810-2907? I mean I will dial 415-810-2001 instead of my landline 415-810-2907. If so how will I configure my router?
Thanks and regards,
Jerry S.
Mohannad Abdullah
Frequent Visitor
Frequent Visitor
looks like you are using FXO ... then whatever call is ringing on this FXO port it will be routed to the number specified in the connection plar command under the voice port.
The Only way is to have the Analog Line from service provider with the same last 4 digits as your extension to call it ... but you will have to add a connection plar command under the voice port again...
Cheers,
M
5 Replies 5
Mohannad Abdullah
Frequent Visitor
Frequent Visitor
Cheers,
M
yes, you are right. Though I  got all my objectives  using my lab kit with 2 analog phones connected to my fxs ports, pstn line to fxo port and the 2  Cisco IP Phones Phones .
Out of curiosity, would it be possible to call the extensions lines be it analog phones or the ip phones directly instead of the analog line telephone number?  Is there any configuration to link the analog line #  with the extensions number that instead of dialing the analog phone number, you can dial directly the extension number.
Thanks.
Hi Mekeniabe,
i guess that you need to add analog phone connected to FXS Port into your cucm cluster ...
Then you need to configure it with an extension in CME or CUCM server but using this way your analog phones wont be part of PSTN Phones and you will not use FXO Ports ..
Please Post your configuration to understand the scenario ..
Cheers,
MO Giacobbe
MCSD, SCJP, CCIE Collaboration #50401
Hi Mohannad,
I am just starting  studying CCNA Voice ( self study ) and I do really appreciate you for your time in replying to my query. Thank you so much. Below is the configuration which I deleted some of the part which is not necessary in my questions.
When a call comes in on the FXO port, it is sent to pilot 2001 (ephone-dn 50) which is configured as the 2nd button on the two phones ( 2:50 ). The two Cisco Phones will then ring simultaneously.
Therefore, If I make a call from my  cellphone and dial my PSTN line ( see attached diagram ) 1-415-756-3864,  the call is routed both on the 2 IP Phones, ext's 1001, 1002.
Just for curiosity or further studies, is there a configuration  on this router to  dial directly the extension numbers , e.g. 1001 and 1002  instead of dialing the pstn line # 1-415-756-3864.
say I can  dial 1-415-756-1001 directly or 1-415-756-1002 if I want.
Thanks.
2811#show run
Building configuration...
Current configuration : 11772 bytes
version 15.1
hostname C2811
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
bind control source-interface FastEthernet0/0.25
bind media source-interface FastEthernet0/0.25
registrar server expires max 3600 min 120
voice register global
mode cme
source-address 172.25.140.1 port 5060
max-dn 40
max-pool 42
tftp-path flash:
create profile sync 000490728535965A
voice register dn 1
number 2001
allow watch
name PH-2001
label 2001
mwi
voice register dn 2
number 2002
allow watch
name PH-2002
label 2002
mwi
voice register dn 3
number 2003
allow watch
name PH-2003
label 2003
mwi
voice-card 0
tftp-server flash:/Ringtones/KotoEffect.raw alias KotoEffect.raw
voice-port 0/0/0
connection plar opx 2001
caller-id enable
voice-port 0/0/1
voice-port 0/1/0
caller-id enable
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
dial-peer voice 5 pots
destination-pattern 91..........
port 0/0/0
forward-digits 11
dial-peer voice 10 pots
destination-pattern 4001
port 0/1/0
dial-peer voice 20 pots
destination-pattern 4002
port 0/1/1
dial-peer voice 7 pots
destination-pattern 1000
port 0/0/0
telephony-service
moh-file-buffer 2000
max-ephones 30
max-dn 50
ip source-address 172.25.140.1 port 2000
ephone-dn 1
number 1001
label Sunga
description Jerry
name Mustang
hold-alert 30 originator
ephone-dn 2
number 1002
label 1002
description Portia
name Phone 2
ephone-dn 3
number 1003
label 1003
--More--
Jun 30 04:03:48.431: %IPPHONE-6-REG_ALARM: 25: Name=SEP0015F95041A9 Load=8.1(2.0) Last=Initialized
Jun 30 04:03:48.431: %IPPHONE-6-REGISTER: ephone-1:SEP0015F95041A9 IP:172.35.140.12 Socket:1 DeviceType:Phone has registered.
description Phone 3
name Phone 3
ephone-dn 14
number 6112
name Sales
paging ip 239.1.1.1 port 2000
ephone-dn 50
number 2001
trunk 1000 monitor-port 0/0/0
ephone 1
device-security-mode none
description Home Office
mac-address 0015.F950.41A9
paging-dn 14
button 1:1 2:50
ephone 2
description Mustang Office
mac-address 0015.F92E.D21A
paging-dn 14
button 1:2 2:50
C2811#
The only you could dial 1-415-756-1001 or 1-415-756-1002 from outside network (your cellphone/PSTN) is by getting those numbers from your service provider.
Internally, you can achieve this by translation rules.
