CDR error on CUCM 6.1.2
ayoussef.kamal
Experts,
I am facing error code 10021 when exporting CDR report from CUCM 6.1.2. AQfter searching on Cisco site, i found the below link
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080933fcf.shtml#Problem2
i did that solution, Am i wait till next midnight to let CUCM to collect new reports or that solution will not solve my problem.
any ideas? did anybody face/overcome this problem before?
BR,
kusatija
Hello!
Is the loader set to 24*7? if yes and if you restarted the Car schedular service then you should see reports being generated as per the doc you mentioned.
But the 10021 error can come because of other reasons as well, most of the time the car schedular service fails, or is not able to process a bad cdr file.
If the above does not work, please provide the folloing from the CLI of the publisher:
run sql select * from car:tbl_system_preferences
file list activelog /cm/cdr_repository/preserve/
file list activelog /cm/cdr_repository/processed/
Kunal
Regarding,
I did 24*7 AND restarted Car schedular
Regarding the Shows you need, as follows:
admin:run sql select * from car:tbl_system_preferences
param_name                param_value
MIN_DATE                  05/14/2011
MAX_DATE                  06/07/2011
CDR_MIN_DATE              05/14/2011
CDR_MAX_DATE              06/07/2011
MAX_CDR_NUMBER            2000000
MAX_ERROR_RECORD_ID       40978637
COMPANY_NAME
TOLL_FREE                 1800,1855,1866,1877,1888
CHARGELIMIT               200.00
GOOD                      20.00
POOR                      30.00
DEFAULT_CAR_USER          _unspecifieduser
LOADER_STATUS             1
CONTINUOUS_LOADING_24_7   1
LOAD_CDR_ONLY             1
MANUAL_PURGE_STATUS       0
LOADER_SCHEDULE_BACKUP    DailyCdrLoad,L,1440,-1,00:00:00,0,300,30
PURGE_LOW_WATER_MARK      80
PURGE_HIGH_WATER_MARK     90
MIN_CAR_DATABASE_AGE      30
MAX_CAR_DATABASE_AGE      60
LAST_PROCESSING_DIRECTORY 20110606
LAST_PROCESSING_FILE      cdr_Barclays-IPT-Cluster_06_201106061316_14866
LAST_PROCESSING_DATA_ROW  96
UPDATE_STATISTICS_DATE    06/12/2011,0
LOADER_BATCH              600,600,2500,3000
INSTALLATION_DATE         6/25/2009
admin:file list activelog /cm/cdr_repository/preserve/
   20110513
   20110514
   20110515
   20110516
   20110517
   20110518
   20110519
   20110520
   20110521
   20110522
   20110523
   20110524
   20110525
   20110526
   20110527
   20110528
   20110529
   20110530
   20110531
   20110601
   20110602
   20110603
   20110604
   20110605
   20110606
   20110607
   20110608
   20110609
   20110610
   20110611
   20110612
   20110613
dir count = 32, file count = 0
admin:file list activelog /cm/cdr_repository/processed/
   20110513
   20110514
   20110515
   20110516
   20110517
   20110518
   20110519
   20110520
   20110521
   20110522
   20110523
   20110524
   20110525
   20110526
   20110527
   20110528
   20110529
   20110530
   20110531
   20110601
   20110602
   20110603
   20110604
   20110605
   20110606
   20110607
   20110608
   20110609
   20110610
   20110611
   20110612
   20110613
ok, so the files do seem to be there in the cdr preserve and process  folders, still car schedular is failing...and the last files processed  are :
LAST_PROCESSING_DIRECTORY 20110606   , that is till the 6th.
Can you provide the screenshot of the table information from the path:
CAR tool>>system>>database>>manual purge, plz provide the screen shot of the billing table.
Can you do a manual purge to the database that should fix the issue.
Hit on the manual purge option, a new window would start showing that the process is executing, once done, hit the close tab.
Check the reports the next day, they should be there..
Kunal
Vishal Gogia
MAX_ERROR_RECORD_ID > MAX_CDR_NUMBER
This looks weird.
Along with the info that Kunal provided, can you also send me the output of following queries:
run sql select count(*) from car:tbl_billing_data
run sql select count(*) from car:tbl_billing_error
Looks like the DB is full. Manual Purging of data is needed.
TnR
Vishal
