IP Telephony and Phones
Labels
OK, I have a question, that I am sure somebody has already ask, but thought I would ask as well.Is there any way to combine all the different system views of RTMT into a single instance. I am running CUCM 8.5.1, Uconn 8.5.1, Presence 8.5.3 and UCCX 8...
PSTN -(SIP Trunks)->VGW3845 -(SIP dial-peer)-> CUCM 8.0 --> Unity call handler --> CUCM route pattern -SIP Trunk-> same VGW3845 --> fax server. once the user dial the fax extension i can't hear the fax tone however if i forward the call from the VG...
Experts,I am facing error code 10021 when exporting CDR report from CUCM 6.1.2. AQfter searching on Cisco site, i found the below linkhttp://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080933fcf.shtml#Problem2i did that sol...
Hello All,I have AIM-CUE version 8.0.2I want to check with you guys if anyone has custom script which says "Welcome and then press 1 for Nick, 2 for Dean or press 0 for operator.If anyone has basic script like this,it would be helpful.Please let me k...
kbeelwar by Level 1
  • 589 Views
  • 2 replies
Hello to allmy voip network is as attachment pic.so i want to use fax on my network, and for using that i install 1 VG-224-FXS on my networki config vg224 as MGCP gateway,so i can call numbers in CUCM and can recieve fx from outside of the companythe...
