CDR files not pushing to ftp
Hi Guys,
We are using Cisco 2921 router with universal image and uck9 license. We have configured the device to push the cdr files to the ftp server.
gw-accounting file
primary ftp ipaddress/dev/can/cdr username xxxxx password 7 xxxxx
I can see the cdr files on the device flash. But not on the ftp server.
router#sh flash | i cdr
37        9440 Jul 26 2012 09:56:00 +08:00 cdr.can-rtr-1.07_26_2012_09_56_00.702
74      258202 Apr 4 2013 12:34:04 +08:00 cdr.router.04_04_2013_11_04_03.754
75      734400 Apr 5 2013 12:34:04 +08:00 cdr.router.04_04_2013_13_01_15.429
76     1167124 Apr 6 2013 12:34:04 +08:00 cdr.router.04_05_2013_12_55_58.952
77      128766 Apr 7 2013 12:34:04 +08:00 cdr.router.04_06_2013_13_25_06.846
78      881012 Apr 8 2013 12:34:04 +08:00 cdr.router.04_07_2013_13_34_05.041
79     1474428 Apr 9 2013 12:34:04 +08:00 cdr.router.04_08_2013_12_48_17.370
181    1367854 Apr 10 2013 12:34:04 +08:00 cdr.router.04_09_2013_12_40_52.828
182      81086 Apr 10 2013 12:57:42 +08:00 cdr.router.04_10_2013_12_41_50.908
It works if i manaully copy from the router to the ftp user.
Any assistance. Much appreciated.
Nachi
10 Replies 10
Aman Soi
Hi Nachi,
Was this working setup or fresh installation?
Can u share the ouput of following commands:
a. show version
b. show running -config
regds,
aman
Hi Aman
This is a working setup. It stopped working suddenly. We have not changed anything in the configuration.
Show version:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(3)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 13-Jun-12 14:24 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M12, RELEASE SOFTWARE (fc1)
router uptime is 2 weeks, 1 hour, 46 minutes
System returned to ROM by reload
System restarted at 13:48:48 AWST Wed Apr 10 2013
System image file is "flash0:c2900-universalk9-mz.SPA.152-3.T1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 2576320K/45056K bytes of memory.
Processor board ID xxxxxxxxx
4 Gigabit Ethernet interfaces
11 Serial interfaces
4 terminal lines
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
8 Voice FXS interfaces
2 Cellular interfaces
1 Services Module (SM) with Services Ready Engine (SRE)
   Cisco Unity Express 8.6.1 in slot/sub-slot 1/0
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
1000944K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9         xxxxxx
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            uck9          Permanent      uck9
data          None          None           None
Hi Nachi,
Is ftp service working on server?
Which third party server is deployed? After u deploy the application on PC/Server used for recieving CDR, there would be application related service.Is that working?
regds,
aman
Hi Aman,
FTP server is working. I can push the files to the ftp server using copy command from the router.
Since the server is not under our control, I am not sure about the third party server platform and the application running on the server. What sort of application are you referring to ? I can try to find it out.
Nachi
Hi Nachi,
What I understand is that u are transferring the CDR raw data from router to FTP server where u are running the third party software for customizing the reports ?
I am referring to that 3rd party s/w?
If it is not so, then, how u are analysing the CDR files.
regds,
aman
Hi Aman,
Thank you for your response.
I will find out how the CDR files are anlaysed. But my problem is the cdr files on the router flash is not automatically getting transferred to the ftp server.  Is that somehow related to the third party software related to customizing the report. Is the third party software initiating the transfer.
Nachi
Hi NAchi,
As u have said that u are able to manual copy the files from router flash to that server but ftp is not working.
There has to be some handshake between router and server to fetch the files.On which OS platform , application is installed.
Just cross-check and let me know.
Customizing the report is a secondary part since first we need to push the files from  Router flash.
In the meantime,you can also run debug ip ftp on router to troubleshoot further.
regds,
aman
Hi Aman,
The server is running standard FTP client. No other third party software. The router initiates handshake process to the ftp client. Then it tries to copy cdr file to the ftp, since it fails it write the cdr files to the flash.
Then, I am manually able to copy from the flash to the ftp.
Nachi
Hi Nachi.
Please activate the following debug.
debug voip fileacct
debug voip dump-file-acct
Give the command: file-acct flush without-close
And post the output.
THX
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Nachi,
Can u initiate the debug as suggested by Mr. Carlo and debug ip ftp so that we can troubleshoot further?
regds,
aman
