02-22-2009 11:44 AM - edited 03-15-2019 04:22 PM
We are running UCM 6.1. Recently I pulled a CDR report for a department. I only see outgoing calls on the report. Is there a way to configure CDR to generate reports for incoming calls too? Thanks,
Yiwen
02-22-2009 12:51 PM
You can get it from here:
User Reports > Top N > By Charge or by duration
then it will be the " incoming " part of your report which represent Inbound calls that originate outside the Cisco Unified Communications Manager network and enter the Cisco Unified Communications Manager network through a gateway.
wish this be helpful
Best Regards
02-22-2009 10:16 PM
CDR logs all calls, you cannot configure it for only inbound or only outbound
java
if this helps, please rate
03-21-2009 08:52 PM
I tried it and got what I needed. Thanks!
Yiwen
