IP Telephony and Phones
Labels
Hi,We have a setup with two Cisco routers connected to two E1 R2 circuits (one per each one). Gateway is H323 controlled.Call Manager is 4.1(3).I have a Route Group for each one of the E1s and those Route Groups are in a Route List, which in turn is ...
dknov by Level 3
  • 737 Views
  • 1 replies
Hi,I have CUCM 6.0 running in the network, Cu has remote site where we required BACD should runnI have 2811 router with 12.4 15T IOSI need a running config of BACD script.Consider my dial in number is 8 digit Please post guys i need it urgently.I hav...
by Not applicable
  • 442 Views
  • 2 replies
Hi,I have a CME router connecting to the gatekeeper and i have made a trunk from CCM to gatekeeper Config :-CMEdial-peer voice 1 voip destination-pattern [1-2]...$ voice-class codec 1 session target ras tech-prefix 1gatekeepershow gatekeeper endpoint...
by Not applicable
  • 753 Views
  • 2 replies
Hi list,I have tried configuring VPIM networking between Cisco Unity and CUE couple of times however it never seems to work. Can anybody explain the proper procedure to configure the same. You can refer to following scenario,CUE ID - 200Unity ID - 10...
Hi i am facing a problem with the ccm 4.0 telephone directory when i clcik the directory it prompt for the username , password and realm instead of missed calls recived calls and placed number.for voice messaging we are using Unity too.please help ...
Resolved! 911!
CM4.2.3I am setting up a site where the pstn gateway is located in a data center physically separate from the actual users. My problem is when the end user calls 911 it will show the location of the data center not the office location where the user ...
dvanzee by Level 2
  • 1869 Views
  • 10 replies
i'd like to setup a lab that consist of call manager and unity (at least ver 5), a switch /w poe, and couple of cisco ip phones (7961). is there an evaluation version of call manager and unity that can run on vmware? if so..how can i get a copy?
rrdumag67 by Level 1
  • 653 Views
  • 1 replies
