CDR not logging phone calls.
Mike Bowers
Hello, I'm just getting into Voice and trying to save Call Detail Records to the buffer of a 2800 series router running CME 8.6 with two 7940 ip phones.
I have CME set up and I'm placing a call and connecting between two extensions after following the book example to set CDR up.
Basically, the book example just shows the following commands:
logging buffered 512000
dial-control-mib retain-timer 10080
dial-control-mib max-size 700
Then, when I Place a call between two phones I have set up and answer the call. I check the logs(show logging) and no CDR info is logged like the pictures show. This is getting very frustrating but appears like it should be very easy to set up.
Is there something I am missing?
Dear, Please refer below link, it must work.
http://www.cisco.com/c/en/us/support/docs/voice/h323/14068-cdr-logging.html
Suresh
Mike Bowers
Is there more to the CDR configuration than the above?  We're trying to track down who's been accidentally dialing 911 and I'm puzzled as to why CDR is not logging anything in the buffer when I try to test.
Suresh
