CDR Reports Issue
opnineopnine
I have CDR with my cucm 10.5, the issue is I have 2 E1 and I would like to know how I can configure the CDR to give me the report to what E1 is the calling connected.
Thanks.
Hi opnineopnine,
 when you configure a gateway using SCCP, this info appears in CDR as SKIGW<last 10 characters of MAC> and with Module and Slot info that you configure in CUCM ... check your CDR for that info.
Hope this helps.
5 Replies 5
kinman-wong
If you are using MGCP, the CDR should have the indication which E1 making the call.
Hello kinman-wong
Im now using mgcp al goes via sccp.
thanks.
Hi opnineopnine,
Hope this helps.
Marcelo,
Is there any software that you can recommend to read the output?
thanks
Hi opnineopnine,
 although CUCM has a tool called CAR (check this link), I prefer to use Excel to read the CDR for this kind of things (like a quick look in one of its data).
 The CUCM's CDR is in a .CSV format.
Hope this helps.
