03-20-2009 09:02 AM - edited 03-15-2019 04:59 PM
-CUCM6.1
-SRST router with FXO lines. h323
Under voice-port, configure the target number '91800xxxyyyy' and let the incoming call back to PSTN
Q)is there any feature to release the call from SRST router?
Thanks in advance,
03-20-2009 09:44 AM
Short of shut/no shut the voice-port, there's no way. There is also a"clear voice call" command, but it's broken in most IOS versions.
03-20-2009 10:04 AM
I may not explained clearly.
the incoming call forwarded to 1800 (PSTN) in SRST router but the call still stay in SRST router until hang-up and also occupy two FXO lines.
Is there any way to release from SRST router after the incoming call forwared to 1800(PSTN)?
John
03-20-2009 04:45 PM
If you configure CFA at router level, it is normal that each call will take two lines.
If you want CFA not to take any line, configure it at telco level.
