12-16-2010 05:17 AM - edited 03-16-2019 02:28 AM
Hi All,
Hope i can seek a little helps here.
I have a router which act as a h323 gateway for CUCM and the gateway have two trunk, 1 is PRI to PSTN and the other one is QSIG
to BT System.
The issue now is when a BT Phone did a CFwdALL to external PSTN no or DN in CUCM, the PSTN call to BT Phone will not get forwarded.
the same goes for an IP Phone calling BT Phone. However, call from another BT Phone will have the call routed to forwarded number succesfully.
I've done a debug isdn q931, look like the h323 gateway doesn't process the Facility IE send by the BT system (which rerouting the call to
forwarded number), hence the call failed.
Anyway I can get the call forward/call divert work in this case? or h323 doesn't support call forward for QSIG? does this related to hairpinning?
do i need allow-connections h323-h323?
Note: call between CUCM, PSTN, BT system is working fine, except the call forward, I guess the dial-peer is setting up correctly.
Anyone is very much appreciated. Thanks
Alex
e.g 97777(IP Phone) is calling 96666(BT Phone), which is CFwdALL to 97778(IP Phone), call from PSTN is having the same
issue too.
13928743: .Dec 16 06:40:12.894 UTC: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8 callref = 0x2265
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98382
Exclusive, Channel 2
Calling Party Number i = 0x0081
HOSTNAME#, '97777'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '96666'
13928744: .Dec 16 06:40:12.910 UTC: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xA265
13928745: .Dec 16 06:40:13.002 UTC: ISDN Se0/2/0:15 Q931: RX <- FACILITY pd = 8 callref = 0xA265
Facility i = 0x9FAA06800100820100A14002023E5502011330370A0101300CA50A0A010412053936313735020101400504038090A3A109A00780053936333138820102A40CA00A800539363137370A0103
Facility IE to Decode:
<**************************** mt decode start ************************>
Facility Ie Data:
Network Facility Extension: Len: 06
sourceEntity: endPINX
destinationEntity: endPINX
RoseAPDU InvokePDU: Len: 40
invokeId: 15957
callRerouting:
reroutingReason: cfu(1)
calledAddress:
partyNumber:
privatePartyNumber:
privateTypeOfNumber: localNumber(4)
privateNumberDigits: 12, Len: 05
"97778"
diversionCounter: 1
pSS1InfoElement: 40, Len: 05
04 03 80 90 A3
lastRetroutingNr:
presentationAllowedAddress:
unknownPartyNumber: 80, Len: 05
"96666"
SubscriptionOption: notificationWithDivertedToNr(2)
callingNumber:
"97777"
screeningIndicator: networkProvided(3)
<**************************** mt decode end **************************>
13928780: .Dec 16 06:40:37.424 UTC: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x2265
Cause i = 0x8290 - Normal call clearing
13928781: .Dec 16 06:40:37.432 UTC: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8 callref = 0xA265
13928782: .Dec 16 06:40:37.432 UTC: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x2265
12-16-2010 03:22 PM
Any luck that someone can help?
12-16-2010 08:12 PM
any recent upgrades, how many servers involved?
12-16-2010 08:21 PM
Hi mhafbnet,
Not sure why is this related, but to answer you, there isn't any recent upgrade on cucm or server.
the issue surface when BT user trying to do call forward/divert.
Alex
01-21-2011 12:54 AM
Any kind soul out there can help on this?
01-21-2011 03:04 AM
Hi Alex,
When call is made from IP Phone or PSTN, PBX sends the facility msg with diversion info. CUCM/GW should decode it and redirect call accordingly.If decoding is failed, it will not be able to send call to forwarded destination
But when you make call from BT phone, in that case, is made to diverted number. So, even if CUCM/GW fails to decode the facility, call will go to destination, may not have the orignally called number.
I am assuming that CUCM/GW is having issue decoding the facility msg. Can you collect the following
debug isdn q931
debug voip ccapi inout
debug cch323 all
If you can attach the GW config, that will be great.
Thank you
- abu
01-24-2011 06:04 PM
Hi Abu,
I've added a command "qsig-decode" and apparently that it solved the forwarding issue. However, new issue surface : )
Now when the IP Phone called a BT Phone which forwarded to another IP Phone,
The calling party will not hear any ring back.
I've tried the tone ringback & progress_ind alert command but no avail.
I'm thinking that since the inbound and outbound call on the GW to BT system is on the same VOIP dial-peer (hairpin), should I add the command "delay transport-address" to generate the ringback?
Would you able to comment on this?
Alex
01-05-2012 01:42 AM
Alex,
I am having a similar issue linking from CUCM 8.0 to an Avaya system using a QSIG link on a H.323 gateway.
I do not think that the facility message is being processed by the Cisco gateway as I am not getting name or number information displayed on Cisco phones when called from an Avaya phone. Also when I call from a Cisco phone to an Avaya phone and the call is unanswered an forwarded to voicemail the call fails because I guess the rerouting information from the Avaya is not decoded properly.
If you did manage to resolve this would it please be possible to see a copy of your gateway configuration?
thanks
James
01-05-2012 08:42 AM
James,
This seems like an issue with QSIG path replacement.
Look on the interoperability portal and find a set up similar to yours
You may need to look under older version of CUCM for QSIG over E1/T1 etc
http://www.cisco.com/en/US/netsol/ns728/networking_solutions_program_category_home.html
When you find a similar set up look for the CUCM set up
for PINX, The pickup group required and the service parameters for
path replacement
Alex
