Change name on Cisco IP Phone 7942
mohsinksa1
Hi Guys ,
  I have  Cisco IP Phone 7942 and it has top right on the screen my friends name . I want to change it to mine . Can you please help me how to change the display name on  Cisco IP Phone 7942 .
Waiting for your replies
Manish Gogna
Go to the Phone Configuration page on cucm, select the directory number and edit the "Line Text Label" filed. Save and Reset.
Manish
- Do rate helpful posts -
Dear Manish Gogna ,
  Can you please show me step by step . Because i don't know anything about cucm
I hope you have access to cucm admin page. If yes, Login into CUCM admin page > Device > Phone > search and select your phone > Click on DN on left side > Search for Line Text Label and edit the field > Save and Reset from top.
Manish
dear can i change display name on ip cisco phone 7821 from command interface on router for example :
voice register dn 7
number 102
name Ahmos Elquadi
no-reg
label Ahmos Elquadi
mwi
voice register pool  7
 busy-trigger-per-button 1
 id mac 5067.AE21.9A74
 type 7821
 number 1 dn 7
 cor incoming mobile-long default
 presence call-list
 dtmf-relay rtp-nte
 codec g711ulaw
so can i change the name for new employee from router (2911)
please help
amr alrazzaz
