Change the URL of PCA
dspooner07
Does anyone know where the PCA URL is configured in Unity?  I would like to change it and I think I have been through every configurable area and cannot find it.  I also could not find the setting in any of the documentation.
Many thanks!
Rob Huffman
Hi there,
You can find the configured Hostname via;
From the Cisco Unified Communications Operating System Administration window, navigate to Settings > IP > Ethernet.
The Ethernet Settings window displays.For a description of the fields on the Ethernet Settings window, see Table 4-1.
Table 4-1     Ethernet Configuration Fields and Descriptions
Field
Description
DHCP
Indicates whether DHCP is Enabled or Disabled.
Hostname
Displays the host name of the server.
IP Address
Displays the IP address of the system.
Subnet Mask
Displays the IP subnet mask address.
Default Gateway
Shows the IP address of the network gateway.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/os_administration/guide/8xcucosag040.html
Cheers!
Rob
"What you don't have you don't need it now"
- U2
5 Replies 5
Opss... I edit this message, wrong answer...
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Aaron Harrison
Which bit are you trying to change? If you are talking the hostname/FQDN part, maybe... if you want to change the relative part of the URL after the FQDN/hostname it's probably not possible.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks for the reply Aaron.  I will back up a bit to explain better.  When users go to https://hostname/ciscopca they aew able to login, but when they click the Web Inbox link, the get "the website cannot be displayed" error where the messages should be listed.  If the navigate to https://ipnumber/ciscopca, all works fine.  The host name used to work, but I'm not sure when it actually broke.  It seems there is a resolving problem, so I wanted to check the configuration to see what Unity had listed as the hostname, but could not find this setting anywhere.
Thansk again!
Rob Huffman
Hi there,
Field
Description
DHCP
Hostname
IP Address
Subnet Mask
Default Gateway
Cheers!
Rob
- U2
Thansk Rob, that was exactly what I was looking for!
