Changing Application Username in Unity Connection 10.5
Derek McCormick
Is it possible to change the application username in Unity Connection 10.5. I see you can do it via the CLI for CUCM, but there is a warning not to do it for Unity connection as it will cause the application to stop function.
Does anyone know if this is possible?
Cheers,
Derek
George Thomas
Level 10
Level 10
I havent done this first hand but it sounds like this change is not supported from the CLI but do it using the GUI.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/security/guide/10xcucsecx/10xcucsec040.html
Please rate useful posts.
