08-27-2018 12:01 PM - edited 03-17-2019 01:24 PM
Is this article correct in the procedure I need to follow to re-ip my CUCM cluster, sounds like I re-ip SUBs then PUB? Do I have to reboot whole cluster after each SUB re-ip? When I make the set network cluster publisher does that node reboot? Thanks
https://networkingnerd.net/2010/12/29/changing-callmanagers-ip-address/
Solved! Go to Solution.
08-27-2018 12:12 PM
There are specific guides for this at cisco.com, for each release.
Make sure to thoroughly read and understand the steps for what you're trying to do to avoid any issues.
08-27-2018 12:12 PM
08-27-2018 02:42 PM
Cisco Prime Collaboration Deployed (PCD) can be used to streamline the process for you as it supported re-hosting/IPing supported versions.
