Changing Service Parameter Configuration in CUCM required any restart?
MehmetKaya
Hi All,
From CUCM 8.5.x If I have changed any configuration on "service parameter configuration". Is it required the any service or cucm restart?
Path:
CUCM CM Administration >> System >> Service Parameters >> Call Manager ...
Those changes do not require a restart.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
7 Replies 7
Aaron Harrison
In general, most apply immediately. Some may not - certainly for some of the other services a restart is required.
What specific parameters are you changing?
Aaron
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
"CDR Enabled Flag"  make enabled
" CDR Log Call with Zero Duration Flag" make disabled
also
I think If any changes required the reset or restart there is a pop-up will appears isn't is?
Aaron
Thanks.
Hi @Aaron Harrison
Hope you're doing fine. I would like to make changes on the Auto Answer Timer. Does this require a restart? Does Cisco have a list or documentation for the services that requires and does not require a service restart?
Thanks!
Ken
No and not that I’m aware of to answer your respective questions.
Response Signature
I wonder if the following parameter require the restart of any services.
Local route group for redirected calls. Thank you.
