09-23-2012 11:51 AM - edited 03-16-2019 01:20 PM
Hi!!
I have a problem with the number shown when i make a outgoing call in the end client in certain BRI
Here is what client want:
These extension, from 4114 to 4120 they want to go to PSTN only from BRI 0/3/0 and 0/3/1 and show 91751XXXX
The rest of the company need to go to PSTN from BRI 0/0/0 .... to 0/2/1 and the rest of the extension, 4110 to 4113
These extension are registered via H.323 trunk to a CUCM sited via wan in other city. so, in the router which there are installed the BRIs only is for SRST issues, and for outgoing and ingoing calls.
In the debugs shows all right the number shown, and the Calling Party transformation Mask in the CUCM is right to in the DNA, but the BRI is not right, here is the debug:
voice translation-rule 2
rule 1 /4114/ /91751XXXX/
rule 2 /4115/ /91751XXXX/
rule 3 /4116/ /91751XXXX/
rule 4 /4117/ /91751XXXX/
rule 5 /4118/ /91751XXXX/
rule 6 /4120/ /91751XXXX/
voice translation-profile PSTN1
translate called 1
voice translation-profile outgoing
translate calling 2
dial-peer voice 170 pots
translation-profile outgoing outgoing
preference 1
answer-address 4114-4116,4118-4120
destination-pattern 99........
port 0/3/0
forward-digits 9
dial-peer voice 180 pots
preference 2
port 0/3/1
forward-digits 9
dial-peer voice 171 pots
preference 3
answer-address .
port 0/0/0
forward-digits 9
dial-peer voice 181 pots
preference 4
answer-address .
port 0/0/1
forward-digits 9
And for choose these extension to go to PSTN to these are the dial-peer:
preference 1
port 0/3/0
forward-digits 9
preference 2
port 0/3/1
forward-digits 9
preference 3
answer-address .
port 0/0/0
forward-digits 9
preference 4
answer-address .
port 0/0/1
forward-digits 9
Is these right or missing things?
Debug isdn q931 show the number correctly changed when i call from extension 4114-4120 but not for BRI 0/3/0 or 0/3/1 , goes for 0/0/0
Thanks!!!
09-24-2012 07:52 AM
Correction in my previous mail, these are the 3 dial-peer configurated
preference 1
port 0/3/0
forward-digits 9
preference 2
port 0/3/1
forward-digits 9
preference 3
answer-address .
port 0/3/0
forward-digits 9
preference 4
answer-address .
port 0/3/1
forward-digits 9
The ext 4117 goes to the PSTN with another number shown.
Regards!
09-24-2012 08:44 AM
Are you saying that calls through BRI 0/3/0 do not display the xlated number?
Can you send us
debug voip ccapi inout
debug isdn q931
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
09-27-2012 09:10 AM
Yes, thats the problem, there are 7 ext which i need to go to PSTN from BRI 0/3/0 and 0/3/1 , and need to go with the header of the client 9175172XX
The rest of the ext in the client must to go to PSTN from the rest of BRI, and with header 9177918XX
These are the debug ccapi inout
Sep 27 15:58:49.737: //34760/80C748F19F03/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x32E74E24, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=9175172XX,(Calling Name=Virginia - 4115)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=06xxxxxxxx(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=210, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Sep 27 15:58:49.737: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 27 15:58:49.737: :cc_get_feature_vsa malloc success
Sep 27 15:58:49.737: cc_get_feature_vsa count is 4
Sep 27 15:58:49.737: :FEATURE_VSA attributes are: feature_name:0,feature_time:891279568,feature_id:44510
Sep 27 15:58:49.737: //34761/80C748F19F03/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Sep 27 15:58:49.737: //34761/80C748F19F03/CCAPI/ccCallSetContext:
Context=0x3521F920
Sep 27 15:58:49.737: //34760/80C748F19F03/CCAPI/ccSaveDialpeerTag:
Sep 27 15:58:49.905: //34761/80C748F19F03/CCAPI/cc_api_call_proceeding:
Interface=0x32E74E24, Progress Indication=NULL(0)
Sep 27 15:58:53.377: //34761/80C748F19F03/CCAPI/cc_api_call_alert:
Interface=0x32E74E24, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
Call Entry(Retry Count=0, Responsed=TRUE)
Sep 27 15:58:53.377: //34760/80C748F19F03/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Sep 27 15:58:53.377: //34761/80C748F19F03/CCAPI/cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
Sep 27 15:58:53.377: //34760/80C748F19F03/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x87C8, gcid=0-0-0-0, tag=0x0)
Sep 27 15:58:53.377: //34761/80C748F19F03/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x87C9, gcid=0-0-0-0, tag=0x0)
Conference Id=0xFFFFFFFF, Call Id1=34760, Call Id2=34761, Tag=0x0
Sep 27 15:58:53.377: //34760/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 27 15:58:53.377: cc_api_get_xcode_stream : 4819
Sep 27 15:58:53.381: //34760/80C748F19F03/CCAPI/cc_api_bridge_done:
Conference Id=0x25F0, Source Interface=0x31E18618, Source Call Id=34760,
Destination Call Id=34761, Disposition=0x0, Tag=0x0
Sep 27 15:58:53.381: //34761/80C748F19F03/CCAPI/cc_api_bridge_done:
Conference Id=0x25F0, Source Interface=0x32E74E24, Source Call Id=34761,
Destination Call Id=34760, Disposition=0x0, Tag=0xFFFFFFFF
Sep 27 15:58:53.381: //34760/80C748F19F03/CCAPI/cc_generic_bridge_done:
Sep 27 15:58:53.381: //34760/80C748F19F03/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x25F0, Destination Call Id=34761)
Sep 27 15:58:53.381: //34761/80C748F19F03/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x25F0, Destination Call Id=34760)
Sep 27 15:58:53.381: confID:0x25F0; callEntry1 callID1:0x87C8, type:1; callEntry2 callID2:0x87C9, type:6
Sep 27 15:58:53.381: //34761/80C748F19F03/CCAPI/cc_api_caps_ind:
Destination Interface=0x31E18618, Destination Call Id=34760, Source Call Id=34761,
Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
Sep 27 15:58:53.381: //34760/80C748F19F03/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=34760
Sep 27 15:58:53.381: //34761/80C748F19F03/CCAPI/cc_api_get_called_ccm_detected:
Sep 27 15:58:53.381: //34760/80C748F19F03/CCAPI/cc_api_get_delay_xport:
CallInfo(delay xport=FALSE)
Sep 27 15:58:53.381: //34760/80C748F19F03/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x25F0, Call Id1=34760, Call Id2=34761
Sep 27 15:58:53.649: //34760/80C748F19F03/CCAPI/cc_api_caps_ind:
Destination Interface=0x32E74E24, Destination Call Id=34761, Source Call Id=34760,
Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
Sep 27 15:58:53.649: //34760/80C748F19F03/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=4207)
Sep 27 15:58:53.649: //34761/80C748F19F03/CCAPI/cc_api_caps_ack:
Sep 27 15:58:53.653: //34761/80C748F19F03/CCAPI/cc_api_voice_mode_event:
Call Id=34761
Call Entry(Context=0x3521F920)
Sep 27 15:58:57.677: //34760/80C748F19F03/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x31E18618, Call Id=34760
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Sep 27 15:58:57.677: //34760/80C748F19F03/CCAPI/ccConferenceDestroy:
Conference Id=0x25F0, Tag=0x0
Sep 27 15:58:57.677: confID:0x25F0; callEntry1 callID1:0x87C8, type:1; callEntry2 callID2:0x87C9, type:6
Sep 27 15:58:57.677: //34760/80C748F19F03/CCAPI/cc_api_bridge_drop_done:
Sep 27 15:58:57.677: //34761/80C748F19F03/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=34760, Disposition=0x0, Tag=0x0
Sep 27 15:58:57.677: //34760/80C748F19F03/CCAPI/cc_generic_bridge_done:
Sep 27 15:58:57.681: //34761/80C748F19F03/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Sep 27 15:58:57.681: //34761/80C748F19F03/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
Sep 27 15:58:57.681: //34760/80C748F19F03/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Sep 27 15:58:57.681: //34760/80C748F19F03/CCAPI/cc_api_get_transfer_info:
Sep 27 15:58:57.689: //34760/80C748F19F03/CCAPI/cc_api_get_transfer_info:
Sep 27 15:58:57.689: //34760/80C748F19F03/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x31E18618, Tag=0x0, Call Id=34760,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Sep 27 15:58:57.689: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 27 15:58:57.689: :cc_free_feature_vsa freeing 351FDFC8
Sep 27 15:58:57.689: vsacount in free is 3
Sep 27 15:58:57.881: //34761/80C748F19F03/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x32E74E24, Tag=0x0, Call Id=34761,
Sep 27 15:58:57.881: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 27 15:58:57.881: :cc_free_feature_vsa freeing 351FD8C8
DEBUG ISDN Q931
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x82
Preferred, B2
Calling Party Number i = 0x0081, '9175172xx'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '6xxxxxxxx'
Sending Complete
Sep 27 16:04:51.617: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xCE
Channel ID i = 0x8A
Exclusive, B2
Sep 27 16:04:54.325: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 4106
Sep 27 16:04:54.325: ISDN BR0/0/0 **ERROR**: CC_CHAN_GetIdleChanbri: All channels busy
Sep 27 16:04:54.329: ISDN BR0/0/1 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 4106
Sep 27 16:04:54.329: ISDN BR0/0/1 Q931: Sending SETUP callref = 0x004F callID = 0x90EF switch = basic-net3 interface = User
Sep 27 16:04:54.329: ISDN BR0/0/1 Q931: TX -> SETUP pd = 8 callref = 0x4F
I put that users go to PSTN dialing to get tone the 9, and the rest of the office, the 0. but to go to PSTN need to have the 0 so, never goes to BRI 0/3/0 or 0/3/1 as i highlighted before.
Has to be another way to get some ext goes to PSTN to concret BRI.
There is H.323 trunk between CUCM and the Gw, not a MGCP
09-28-2012 05:15 AM
Finally i resolve the issue with the CUCM, making more partition and more route pattern.
Thanks all!
