Choice of Media Resources
Yuriy Ivkin
Greetings!
I can't find anywhere information, based on which MRGL (callee or called) is happening determination which resources should be used. Also, do both sides have to have transcoder in their MRGL's, or one in any MRGL is good enough ?
Thanks in advance for your answers.
yahsiel2004
Level 7
Level 7
Yuriy,
Whoever initiates a conference, would be that persons MRGL that gets used. In regards to transcoding, each MRGL should have a resource, unless you have a transcoder which hasn't been assigned to a group, which means it could be used by anyone.
Yosh
HTH Regards, Yosh
yahsiel2004
Level 7
Level 7
Yuriy,
Yosh
HTH Regards, Yosh
Thank you!
