ciro voip
nettuno8_20111
but i have a fxs interface for the 2611xm router I configured the router but i only make internal calls how do i send outside calls and associate it with the fxs interface? and how to configure a fxs interface? thanks for your answers
To run internally you need to configure CME, to connect to outside it depends on what type of circuit you have, i.e. standard phone line would be VIC-FXO line along with PVDMs.  Keep in mind this router model is 13+ years behind having any updates on it as they were later replaced by ISR G1, ISR G2, and now ISR 4K, so anything you do will require a "time machine".
8 Replies 8
Chris Deren
You first need to connect an outside line to your router via FXO port for example (assuming you have one). FXS is station line for analog devices (there are FXS-DID external trunks but those are rare).  So, get FXO port, connect to external POTS line and then configure dial peers on the GW to router calls out.
version 12.4
hostname fabio
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 25
no network-clock-participate slot 1
no network-clock-participate wic 0
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.3.100
ip dhcp pool voice
network 192.168.3.0 255.255.255.0
default-router 192.168.3.100
dns-server 8.8.8.8 8.8.4.4
option 150 ip 192.168.3.100
lease infinite
ip dhcp pool default
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
option 150 ip 192.168.1.1
lease infinite
ip dhcp pool ciro
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
option 150 ip 192.168.2.1
lease infinite
ip dhcp pool fabio
network 192.168.4.0 255.255.255.0
default-router 192.168.4.1
option 150 ip 192.168.4.1
lease infinite
ip cef
interface ATM0/0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0/0
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 2
interface FastEthernet0/1
description trunk-to-switch
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
description default vlan
encapsulation dot1Q 1 native
ip nat inside
no snmp trap link-status
interface FastEthernet0/1.2
description ciro vlan
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.3
description voice vlan
encapsulation dot1Q 3
ip address 192.168.3.100 255.255.255.0
ip nat inside
interface FastEthernet0/1.4
description fabio vlan
encapsulation dot1Q 4
ip address 192.168.4.1 255.255.255.0
ip nat inside
interface Dialer2
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 2
ppp pap sent-username fabio password 0 aliceadsl
ip route 0.0.0.0 0.0.0.0 Dialer2
ip http server
no ip http secure-server
ip nat inside source list 102 interface Dialer2 overload
access-list 102 permit ip 192.168.0.0 0.0.255.255 any
control-plane
telephony-service
max-ephones 5
max-dn 5
ip source-address 192.168.3.100 port 2000
auto assign 1 to 5
max-conferences 4 gain -6
ephone-dn 1
number 0001
ephone-dn 2
number 0002
ephone-dn 3
number 0003
ephone-dn 4
number 0004
ephone 1
ephone 2
ephone 3
ephone 4
line con 0
password ciro
login
line aux 0
line vty 0 1
password ciro
login
line vty 2 4
login
end save this and my voip configuration ran the written configuration of the fxs interface, and the configuration association to fxs interface thanks.
nettuno8_20111
version 12.4
hostname fabio
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip dhcp pool voice
lease infinite
lease infinite
ip dhcp pool ciro
lease infinite
ip dhcp pool fabio
lease infinite
ip cef
interface ATM0/0
no ip address
shutdown
no ip address
duplex auto
speed auto
pppoe enable
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside
ip nat inside
interface Dialer2
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
ip http server
control-plane
telephony-service
max-ephones 5
max-dn 5
auto assign 1 to 5
ephone-dn 1
number 0001
ephone-dn 2
number 0002
ephone-dn 3
number 0003
ephone-dn 4
number 0004
ephone 1
ephone 2
ephone 3
ephone 4
line con 0
password ciro
login
line aux 0
line vty 0 1
password ciro
login
line vty 2 4
login
I dont see any pots ports here, so are you looking for what voice-card you need?
Can you post "show diagnostics" and "show inventory".
I would like to communicate with the voip internally to my network, I want to communicate also outside. and my router and the 2611xm. i do not know wic to acquire give me a tip, for now i have an atm like wic
but i would like to write the configuration for making external calls that i can call and receive with an interface fxs internally communicate already. thank you.
hi I have a 2600xm router I have configured the router and I communicate internally, now I would like to make urban calls and receive them how? thank you. I wait for your answers
