Cisco 2911 using VOIP
Satarian22
I am trying to learn VOIP functionality on a cisco 2911. I hope someone on here can help me with this.
I have a VOIP provider called VOIP.MS
I have a Fiber ONT connection going into a Palo Alto Firewall which handles all my routing and DHCP addressing.
The NAT for the internet is located on this firewall.
I've created a VLAN for this voice traffic. VLAN101 / Subnet 192.168.101.0/24
I have placed a Cisco 2911 device on the network running firmware c2900-universalk9-mz.SPA.157-3.M3.bin
interface Gi0/0 is getting a DHCP address of 192.168.101.2
I've setup a route using the command: ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
I'm trying to follow https://wiki.voip.ms/article/Cisco_IOS but I dont have enough understanding to know what is going wrong.
Here is my config for the relevant areas. Let me know if you need other sections.
voice service:
voice service voip
 ip address trusted list
  ipv4 162.213.157.82
 ip address trusted call-block cause not-in-cug
 gcid
 clid substitute name
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  session refresh
  e911
  transport switch udp tcp
  asserted-id ppi
  localhost dns:vancouver.voip.ms
  midcall-signaling passthru
  no call service stop
sip-ua (changed the passwords to a fake number)
sip-ua
 credentials username 226468_cisco01 password 7 13240981231823 realm vancouver.voip.ms
 authentication username 226468_cisco01 password 7 13240981231823 realm vancouver.voip.ms
 registrar 1 dns:vancouver.voip.ms expires 300
 sip-server dns:vancouver.voip.ms
 host-registrar
dial-peer  (changed did to fake number)
dial-peer voice 1 voip
 huntstop
 destination-pattern 5551236541
 session protocol sipv2
 session target sip-server
 dtmf-relay cisco-rtp rtp-nte
 codec g711ulaw
 no vad
I am unsure how this device is suppose to register with my voip provider.
I am not seeing any traffic on my firewall to indicate that this device is attempting registration.
I enabled the debug ccsip but I dont see any console messages at all.
Maybe I misunderstand how this works.
I thank you for the help in advance.
9 Replies 9
Leo Laohoo
I have no idea about others but if you have an "account" with a 3rd part, non-Cisco CUCM environment, I wouldn't do my configuration in the router.
Instead, get something like Asterisk-based or 3CX server and configure these to talk to the voice provider.
So when the Asterisk-based or 3CX is authenticated to the voice provider, the next step is to configure the phones to register to the Asterisk-based or 3CX server.
Hello Leo,
I understand that I can use Asterix to connect to my voip service but I thought I would learn the voice aspect of Cisco IOS.
Am I misunderstanding how the Cisco 2911 works? Should it not be able to make a connection to my VOIP provider directly?
I envision this connection flow but I could be way off.
Cisco 7945 IP Phone -> Cisco 2911 -> Palo Alto FW  Internet -> VOIP Provider
This is a test lab. I only have the one 7945 IP Phone.
Sorry I replied using the wrong account.
That was my reply above.
Hello there,
Have you figured this out? I have the same set up but with a UDM router instead of Palo Alto.
LuckyAces
What does a ' sh dial-peer voice summary' reveal about the status of the dial-peers?
Here is the output of that command:
HL-C2911-01#sho dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS SESS-SER-GRP\  OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE    VRF
1      voip  up   up             7806665194         0  syst sip-server                               NA
 For server-grp details please execute command:show voice classserver-group <tag_id>
 To see complete session target for ipv6 use 'sh running config | section dial-peer <tag>
Please note that I have not connected / configured the 7945 yet.
Also note that when I look at my VOIP provided the account shows as not registered.
Also I don't see any traffic leaving this router except for DNS queries.
falomassor
Hello there,
Cisco IP phone 8851 --> Cisco Switch --> cisco isr 4321 --> UDM --> SIP Provider
Maybe you open a new question and describe in more detail, what is not working.
And I would advise you to attach the config and logs of the CUBE. Otherwise it will be "glass ball reading".
Ok. Thanks I will do that.
