07-07-2013 02:38 AM - edited 03-16-2019 06:15 PM
I am working on a Cisco 2921 router ordered with PVDM3 32 to 128 Channels factory upgrade. The DSP looks good in the inventory. However, I am not able to see / allocate all the resources available. I am unable to allocate more resources then currently are defined for Transcoding, Conferencing and MTP. Do I need to activate / license something ?
# show inventory
NAME: "CISCO2921/K9", DESCR: "CISCO2921/K9 chassis, Hw Serial#: FGL172222P8, Hw Revision: 1.0"
PID: CISCO2921/K9 , VID: V08 , SN: FGL172222P8
NAME: "PVDM3 DSP DIMM with 128 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 128 Channels"
PID: PVDM3-128 , VID: V01 , SN: FOC170260AM
# show dsp-group all
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 32.1.2
Max signal/voice channel: 43/43
Max credits: 645, Voice credits: 645, Video credits: 0
num_of_sig_chnls_allocated: 43
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 645, reserved credits: 0
Signaling channels allocated: 43
Voice channels allocated: 0
Credits used (rounded-up): 0
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 2:
num_of_sig_chnls_allocated: 17
Transcoding channels allocated: 12
Shared credits: 258, reserved credits: 0
Signaling channels allocated: 17
Group: FLEX_GROUP_XCODE, complexity: HIGH
Shared credits: 0, reserved credits: 387
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 3:
Max signal/voice channel: 42/43
num_of_sig_chnls_allocated: 0
Transcoding channels allocated: 7
Shared credits: 27, reserved credits: 0
Signaling channels allocated: 0
Shared credits: 0, reserved credits: 97
Group: FLEX_GROUP_CONF, complexity: CONFERENCE
Shared credits: 0, reserved credits: 461
Codec: CONF_G729, maximum participants: 8
Sessions per dsp: 7
Group: FLEX_GROUP_HW_MTP, complexity: LOW
Shared credits: 0, reserved credits: 60
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
# show dspfarm all
Dspfarm Profile Configuration
Profile ID = 3, Service = TRANSCODING, Resource ID = 1
Profile Description : XCODE Resources
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 15
Number of Resources Out of Service : 0
Codec Configuration: num_of_codecs:5
Codec : g729r8, Maximum Packetization Period : 60
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Profile ID = 2, Service = CONFERENCING, Resource ID = 2
Profile Description : Conference Resouces
Number of Resource Configured : 5
Maximum conference participants : 8
Codec Configuration: num_of_codecs:6
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
Profile ID = 1, Service = MTP, Resource ID = 3
Profile Description : MTP Resources
Number of Resource Configured : 4
Hardware Configured Resources : 4
Hardware Available Resources : 4
Software Resources : 0
Codec Configuration: num_of_codecs:1
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 2 32.1.2 UP N/A FREE xcode 1 - - -
0 3 32.1.2 UP N/A FREE xcode 1 - - -
0 3 32.1.2 UP N/A FREE conf 2 - - -
0 3 32.1.2 UP N/A FREE mtp 3 - - -
Total number of DSPFARM DSP channel(s) 24
Rick.
07-07-2013 04:12 AM
Hi Rick,
You do not need any license to activate PVDMs .U need to have Voice based IOS.
But on ISR G2 series ,in addition to Voice based IOS , also need Unified Communications license. In your case,it is alreay there since u are able to see//configure PVDMs.
Please refer this DOC by Mr. AOK
https://supportforums.cisco.com/docs/DOC-29151
Can u share the output of command show voice dsp group all.
regds,
aman
07-07-2013 04:23 AM
Thanks Aman
The output of "show voice dsp group all" follows below:
#show voice dsp group all
dsp 1:
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 2:
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 3:
Sessions per dsp: 7
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
0 DSP resource allocation failure
Why are the total channels in the output of DSP Farm command equal to 24 only ?
Rick.
07-07-2013 05:31 AM
Hi Rick,
It is a good catch .I have never seriously noticed in O/P but this may be due to Number of Resource Configured which sums to 24[15+5+4] .
regds,
aman
07-07-2013 05:41 PM
Thanks Aman,
Yes, that may be sum of total resources configured. However, I cannot increase the individual count beyond 15, 5 and 4 without decreasing another number. The DSP config looks like this:
voice-card 0
dsp services dspfarm
dspfarm profile 3 transcode
description XCODE Resources
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 15
associate application SCCP
dspfarm profile 2 conference
description Conference Resouces
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 5
dspfarm profile 1 mtp
description MTP Resources
codec g711ulaw
maximum sessions hardware 4
Rick.
07-07-2013 09:50 PM
If you are concern about the DSP utilization, please go ahead and check it with the DSP calculator:
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
