ā01-09-2014 02:40 PM - edited ā03-16-2019 09:11 PM
I have a cisco 3825 that I need the sip call leg entering the switch to be able to offer g729 curently it seems all calls are in G711U. I am not abke to assign "
voice-class codec 1' to the
dial-peer voice 100 pots
any ideas?
ā01-09-2014 02:47 PM
hello fernando
what is the call flow topology?
Br,
Nadeem
Please rate all useful post.
ā01-09-2014 04:29 PM
Thank you for the reply..
call comes in as SIP from GIGE0/0 hits the dialer-peer voice 100 pots that points to a trunk group consisting of the
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
trunk-group ALL
no cdp enable
then out the PRI
ā01-10-2014 12:28 AM
Hi Fernando,
Codec class is not supported on POTS dial-peer , its only for VOIP DP. There is an option you can put it under voice port , which further points to POTS DP.
Rate all the useful post.
Manish
ā01-10-2014 08:48 AM
Thank you but did not see anything about this in the voice-port Do you know why this router does not have the option for
voice service voip
ip address trusted list
ipv4 5.5.5.5
It seems I have no way to limit who can send calls to this device.. I attempted access-list but not sure if correct since if I send calls to it from my signaling server and dont include all customer ips as well it will block the rtp traffci since it is coming from a non-permited IP..
Any ideas?
ā01-10-2014 09:46 AM
There is an option" codec complexity" under voice port but that didn't give intended result which you want.
Can you check by assigning subnet mask next to IP address under ip address trusted list. Like..
voice service voip ip address trusted list ipv4 203.0.113.100 255.255.255.255 ipv4 192.0.2.0 255.255.255.0
And also do let us know IOS version of your router.
Rate all the helpful post.
Manish
ā01-10-2014 10:00 AM
This is what i am getting:
Router(config)#voice service voip
Router(conf-voi-serv)# ip address trusted list
% Invalid input detected at '^' marker.
Here is the info you requested
System image file is "flash:c3825-adventerprisek9_ivs-mz.150-1.M10.bin"
Last reload type: Normal Reload
Cisco 3825 (revision 1.2) with 487423K/36864K bytes of memory.
Processor board ID FTX1224A4WM
2 Gigabit Ethernet interfaces
120 Serial interfaces
5 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
250880K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO3825 FTX1224A4WM
ā01-10-2014 01:49 PM
Hi.
Toll fraud prevention was introduced in release 15.1(2).
I suggest you to upgrade the IOS to the latest release available for 3825 which is 15.1(4)M7
You can negotiate g729 on voip dialpeers pointing to peers supporting that codec.
Carlo
ā01-10-2014 06:33 PM
Thanks Carlo you wouldnt have the bin file would you I dont have a access to download it..
