02-21-2013 12:08 AM - edited 03-16-2019 03:51 PM
We are having Cisco 3845 router with two PVDM 64-channel cards in it. We are noticing error "No More free buffer in vnm_dsprm_free_msg_Q" continously on console.
Current IOS version is 12.4-24.T5 ipvoicek9 image on voice gateway router. I have attached error log
Please suggest on this issue.
MAC
Solved! Go to Solution.
02-21-2013 12:09 AM
Update IOS.
02-21-2013 12:09 AM
Update IOS.
02-21-2013 12:15 AM
Hi Paolo,
Thanks for your reply, Is it a Bug behaviour or it is related to Hardware failure?
Is there any Bug ID released for this version?
MAC
02-21-2013 12:16 AM
Update, and do not worry about bug IDs.
03-15-2013 03:39 AM
We have rebooted the router and now errors are not generating, we will be planning for IOS upgrade later as same IOS is running in all the routers.
MAC
