Cisco 3905 image downloading fail
Evgeny Andreev
on new ip phone 3905 recieve a error "image downloading fail". Try reset to factory default. Didn't help. Any ideas?
Best regards.
47 Replies 47
Thanks ..working fine now !
Hi ,
Many new phone are facing this issue, my issue is first the phone is trying to download firmware from 10.10.24.2 (this is IP is not there in our network but we don't know from this ip comes)  fails and after some time it tries to download firmware from 192.168.1.100 and fails.
I have tried above procedure but it not working.
I have used tftpd64.452 and made DHCP with option 150 . But phones are not requesting for the IP.
But when i connect laptop it is receiving the IP from DHCP server.
Can some one help with details procedure.
Velu S
Hi Velu,
refer the link.Make sure connectvity to tftp server is through when u connect 3905 IP phone for first time.
https://supportforums.cisco.com/discussion/12548546/ip-phone-3905-recieve-error-image-downloading-fail-try-reset-factory-default
regds,
aman
Could you give me this file : vmlinuz my email is reinstall@163.com thanks
Could you give me this file : vmlinuz my email is xjq@netcra.com thanks
we facing same issue please sent the file ...vmlinuz
we facing same issue please send the vmlinuz file ..on raju.jadhav@nirmaldatacomm.com
Would you be so kind to send vmlinuz file on my email alexbulfon@gmail.com
Thank you,
Alex.
I have the same problem with you. Could you please send those files to my email ?
erick.marquez@correo.buap.mx
thanks.
Hi Evgeny ...
I have the same problem too .. Could you please email me vmlinuz file to dheeqz@gmail.com.
Thanks in advance
Im facing the same problem. Would you be so kind to send vmlinuz file on my email  mcapdevila@unitronics.es
Thank you,
Miquel
Hi All,
I already uploaded the vmlinuz file into the dropbox :
https://dl.dropboxusercontent.com/u/67881399/vmlinuz.rar
hope it can help you.
regards,
Taufik
Thanks much dear !
