01-21-2024 09:02 AM
How do I shorten the number of rings before the call minder answer machine kicks in. The phone set does not offer that option in the preferences menu. Thanks
01-21-2024 09:47 AM
The Call Forward No Answer timer is performed by the call control platform, not the phone.
01-22-2024 07:00 AM
If you are using CUCM, go to the Directory Number configuration page and look for the field "No Answer Ring Duration (seconds)". That field determines the number of seconds a DN will ring before the Ring No Answer behavior kicks in.
Maren
