Cisco 6921 IP phone Display name
Ali Bahnam
Dears,
I have a Cisco 6921 phone I registered it with CME 8.6 normally and this can display the username on it.
But when I registered it with Cisco CM 9.1 the display name didn't display on the screen.
Please any ideas for this issue,
Jonathan Schulenberg
You can use the Line Text Label field to set a short text label; however, you cannot set text in the upper-right corner or replace Your current options in CUCM. The upper-right corner is the External Phone Number Mask.
Please remember to rate helpful responses and identify helpful or correct answers.
