10-06-2013 07:32 AM - edited 03-16-2019 07:44 PM
Dears,
I have a Cisco 6921 phone I registered it with CME 8.6 normally and this can display the username on it.
But when I registered it with Cisco CM 9.1 the display name didn't display on the screen.
Please any ideas for this issue,
10-07-2013 08:06 AM
You can use the Line Text Label field to set a short text label; however, you cannot set text in the upper-right corner or replace Your current options in CUCM. The upper-right corner is the External Phone Number Mask.
Please remember to rate helpful responses and identify helpful or correct answers.
Log in to Community
